Question about AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light
Trying to find out how to wire a Lutron SF-10P to a 3-wire system.
  • Kevin O'Brien
    Kevin O'Brien May 11, 2010
    "Three wire" meaning hot, neutral and ground, or do you want to use the dimmer as a three-way switch?
  • 92 Answers
Hi you have many way to connect it go to
good look
Posted on Dec 04, 2008
Hunter 85112-02 Ceiling Fan Receiver
I believe the lutron will connect at the pull switch. That model # isnt workings for me though. I am finding 85112-02 but not 04. You can try googling 85112-02 remote wiring and there are many results. The hunter remote module may stay in place and the lutron will connect via the pull string wires. maybe. If you can confirm the model and maybe the lutron model I can look more.
Jan 10, 2018 | HunterFanCompany Cars & Trucks
We have a Lutron, Skylark S-10 dimmer switch in our MRI room at the Catholic Medical Center in Manchester, NH, which controls (4) Kirlin RR00723-45 recessed can lights w/ 120PAR38 lamps. The problem is...
I would call their tech support line at 1-800-523-9466 (available 24/7). The fluttering is obviously not normal, but in an environment such as an MRI room, there are more troubleshooting steps involved than I think could be delivered in this type of textual back-&-forth environment.
Nov 29, 2010 | Lutron Skylark Incandescent 1000W Preset...
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
Lutron has NT-3PS
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
If the help above does not get you going, answer back with more information and we can help.
Oct 24, 2010 | Lutron Dalia 3Way Dimmer 600W- White -...
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
As a general rule, grounding will not affect operation of dimmer.
Type of dimmer, type of switch being replaced, type of load, and how you connect wires will affect dimmer.
Here is Lutron dimmer switch page
What is the load? Are you wiring dimmer to a ballast? Or fan? Or incandescent lights? Or florescent lights?
Are you replacing a 2-way or 3-way switch?
What color are your dimmer wires?
How many wires were connected to switch?
Can you re-install the switch, and know where each wire went?
Did you replace a light with a fan, and then want the dimmer to slow the fan? Not every dimmer will work with a fan, or florescent lights.
Dimmers cannot dim LED lights.
If I know what type switch you are replacing, and the type of load you want to control, and the specific dimmer you have, I can answer the question.
Oct 12, 2010 | Lutron #D-600PH-DK 600W SP Push Rotating...
My Lutron Rotary Fan Control FSQ-2FH-DK. The box saye can be used for a 3-way as well as single pole, I want to wire it as a 3-way but the unit has only 2 black wires and 1 green wire. how can I wire this...
I don't think that model is for a 3 way switch . It is for fan speed control only. Green is ground, and one incoming and one outgoing "hot" wire. You will need a different part number such as:
Oct 09, 2010 | Lutron FSQ-2F Rotary Fan Speed Control,...
4 can lights wired to two 3 wire Lutron
The interior flood light bulbs were the new flourescent energy savers. I replaced them with incandescent and it worked with the dimmers.
Dec 16, 2009 | Electric Electrical Supplies
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
Jun 27, 2009 | AMS Lutron S2-LFSQ Skylark Dual...
Have a Lutron Skylark SF-10P need to wire to existing 3 wires
You have to have a special ballast on the light to dim fluorescent light fixtures. You also have to have a special dimmer.
Nov 28, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light Logo
122 people viewed this question
Top AMS Electrical Supplies Experts
Craig Butler
Craig Butler
Are you an AMS Electrical Supply Expert? Answer questions, earn points and help others
