I just discovered that the outer tub on my Whirlpool Washer (top-load) is full of pet hair. How can I clean it out?
  • 116 Answers
ONCE A WEEK RUN HOT WATER AND BLEACH NO CLOTHING ,DETERGENT, FILL ONLY HOT WATER LET RUN THE WHOLE CYCLE SHOUKD RESOLVE YOUR PROBLEM
Posted on Nov 30, 2008
Will not spin
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Jul 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a whirlpool ultimate care 2 washer and it has a musty ordor inside the drum. What could be the problem.
the problem is you rarely use hot water wash and probably never use bleach....bacteria forms w/in the outer tub creating a bathtub-like ring around the top edge(not accessible to clean without disassembling) try running a few hot extra large loads w/plenty of bleach to clean the unit out and killl the odor
Apr 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from washer
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make
Jan 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
Feb 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
loosen the screw bolt located at the back cover,it has also a plastic lock in the side to side of the plastic cover,find it by sliding a small flat srew.
Feb 21, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
