Question about Kenmore 62702 Microwave Oven
Blown Fuse on a Microwave
There was a big dish in the oven , it couldn't turn, got caught on the sides and I believe that it caused the fuse to blow. There was a burning smell and I am assuming the fuse blew. How can I replace it?
Kenmore Model # 722.62622200
  • Kenmore Master
  • 9,098 Answers
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let us know if you need further help with torubleshooting.
Posted on Dec 02, 2008
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
What could be causing the fuse to blow in my Emerson microwave oven?
a blown fuse is a dead short of the circuit
it could be a failed power board , control board , megatron, light wire anything powered by the fuse
good advice is to take it in for a proper diagnosis and quote
Sep 30, 2016 | Emerson Microwave Ovens
Why won't my panasonic inverter microwave will not turn on?
check when the fuse is blown,means inverter unit is faulty
Aug 05, 2014 | Panasonic NN-S251 Microwave Oven
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Suddenly it does not work. No clock no light up in the panel.
Open the unit. On top where mains come in would be a big fuse normally 10amp , its blown. This is almost always caused by faulty door switches. Also check diode from the big cap to earth. be careful the cap can store high voltages even when unit is off.Discharge capacitor first with a wire to earth.Make sure the unit is off.The fuse will also blow if that diode is blown.they usually go short circuit.
Apr 02, 2011 | Emerson MW8987B/W Microwave Oven
I have a kitchen aid microwave and have had it repaired at a autherized sevice center and it had a blown fuse. Now I have another fuse that has blown. It does it when the door opens and then blows leaving...
When the fuse blows in the microwave oven, it is often caused by a bad door switch. Sometimes food build up will clog it, or becomes defective, the only way to fix it is have it replaced.
Mar 30, 2011 | KitchenAid KCMS145J Microwave Oven
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
Changing a fuse, Hard?
well its not very hard to do,,, but,,, what caused the fuse to blow?
what fuse has blown as there are at least 3 of them in there, none of them are the same size as a 13 amp plug and most are of the slow blow type,,, even the hight voltage fuse!!! (ei:1000's of volts!) if a fuse has blown its most likely to be the unit getting near the end of its life, and sufferd whats called a "flash over" maybe on the capacitor or the megatron both would pop a fuse, but it will only do it again!! and that next time it could go with a big bang and stink your house out for weeks with a burning smell!!!! and if you dont know what not to tuch inside of this microwave dont go inside of it, it could easly kill you, even with the plug pulled out the wall scocket, there will still be 1000,s of volts kicking about inside of it,,, whats your life worth??????
microwaves are only £50.00p up now,, play it safe buy a new one
Oct 21, 2009 | Maytag MMV5207A Microwave Oven
Microwave runs but does not blow heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))....
Oct 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62702 Microwave Oven Logo
157 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
