Question about Car Audio & Video
Code #2 error on 2005 Hyundai CD - Car Audio & Video
  • ralpert Nov 29, 2008
    I pulled the fuse for a few minutes, then put it back. However, the mechanism still doesn't operate correctly and won't seat the disk.
    Sergeant:
    Champion:
  • 298 Answers
Try getting a CD cleaning kit , to clean the CD player.
the code means (dirty laser can not read). indicating it is in need of a good cleaning.
Posted on Nov 29, 2008
    Scholar:
  • 135 Answers
The 'Error 04' started shortly after I inserted a new CD. The player was set on 'random" and would play util the 'Error 04' came up. I couldn't do anything. Then I pulled the radio fuse, with the key off, (No.25) on my RX 330. I was able to start the CD player and I ejected all of the discs. I put in six new discs and the player worked great. I inserted the suspect disc again and got the 'Error 04" again. I did the fuse thing again and was able to eject the bad disc and put another one in. So far it's working fine. I think the problem was the disc and by pulling the fuse the radio reset itself. Hope it works for you. Owen
Don't forget trkas answer.
Posted on Nov 28, 2008
    Sergeant:
  • 291 Answers
Unplug the device from the car for some time then again connect the wires.
P0430 code tuscon 2005
Check out related help links to troubleshoot these common error OBD code noticed on many brand vehicles:------
1998 GMC K1500: OBD Error Code P0430?http://schematicsdiagram.blogspot.in/2012/06/1998-gmc-k1500-obd-error-code-p0430.html
OBD code P0301, P0430 and P0174?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
These will help.
Thanks.
Nov 23, 2012 | 2005 Hyundai Tucson
U0019 error code on hyundai 55
The u0019 code is a communication failure code on the low speed bus line. You will want to have all modules scanned to see which one is not setting the same code. The module on the low speed bus that is not setting the code is the problem most likly. This particular code is indicating there is an open/short to ground or B+ on the bus line. You will have to find a good electrical shop to diagnose the problem.
Good luck.
Nov 28, 2011 | 2005 Hyundai Tucson
Error code 43 0n my 2008 hyundai elantra cd player
Dec 06, 2010 | Hyundai Elantra Cars & Trucks
I'm putting a new radio in a Hyundai 2005 Tucson and need instructions to remove and re-assemble the dash
the original radio /cd should just remove with the 2 prong loops and the wiring is standard for most replacement cd/tuners {you may need a wiring loop to fit you new radio/cd available from most motor factors inc halfords
STRAKER1999
Apr 01, 2010 | 2005 Hyundai Tucson
Need fil for error code P2626 Hyundai Elantra GLS
P2626 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
I'll sure this has to do with a faulty O2 sensor. This sensor is usually located around the header of your car, or down more on your exhaust.
Try disconnecting your battery for 30 mins, hook it back up, and start your car again. This will erase the error. See if it comes in again.
Hope this help (remember rated this post).
Mar 25, 2010 | 2005 Hyundai Elantra
How do I turn off the service engine code in my 2005 hyundai accent ..code p2096
The code.... P2096.... Post Catalyst Fuel Trim System Too Lean, Bank 2... If this has been repaired you can turn off the light with a scanner tool.....
Feb 12, 2010 | 2005 Hyundai Accent
2005 Hyundai Tuscon has a CD stuck in the radio and displays and error code 2
To attempt to remove the jammed CD ,try teasing it out by using an old CD through the slot.
It that fails to extract it then the player will have to be removed from the dashboard, the metal covers removed + the jammed CD released from the mechanism.
Make sure you have the Security Code before you remove the radio/player
Sep 09, 2009 | Car Audio & Video
My hyundai accent 2005 mp3-01 player won't work
dear friend:the hyundai radio"s does not come with a security code,which means that it is a after market unit and you have to contact the manufacturer with the serial no:
Aug 31, 2009 | 2005 Hyundai Accent
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Error code er 2
I dont want to guess a solution for this however, ERR2 represents EJECT. The description of this error is "The Eject is not available". Possibilities are, jammed mechanism or sticky eject button.
Sep 04, 2008 | 2000 Hyundai Sonata
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
