Question about Philips 42PFL3603D 42 in. LCD TV
42PFL3603D/F7 PHILIPS HDTV
PICTURE LOOKS GREAT WITH BLUE RAY PLAYER ,HOWEVER THE PICTURE GETS DISTORTED WITH FAST MOTION WHEN HOOKED UP TO DISH NETWORK BOX THEY SAID EVERYTHING IS FINE ON THERE END.
  • Shayne Schecht May 11, 2010
    Did you ever get your issue solved? Let me know. I can give you some things to try that may help improve the picture. I have the same set.
  • 124 Answers
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Posted on Mar 03, 2009
I have a sanyo DP50740plasma tv a few years old. Last night I got wi fi and hooked up a Samsung blue ray player and the sound quit working. the picture is clear on dish (on HDMI 3) and the blue ray p
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
Dec 17, 2014 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
Phillips HDTV 42PFL3603D/F7 screen is grey (after phillips power-up logo shows) when plugged in, will not power off, remote led blinks when used, but no change.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | Philips 42PFL3603D/27 42 in. LCD TV
Turned on my Philips 42pfl3603d/f7 and you can see the images but everything is blue what part went bad and can I replace it my self
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
I just bought the sony blu ray and cannot hook it up correctly to the surround sound, dish network and tv. The instructions given from Sony and Philips did not work.
Hi my name is Mike Houston of DISH Network, I see you aretrying to connect your Blu-ray to the surround sound system and you have DISHNetwork. I wanted to get a little more detail about the equipment to betterassist you, I was looking for the model numbers for the Sony and Philipsequipment to look at the configuration as well did you want any of the componentsconnected to the DISH receiver. I will leave you my e-mail to get the componentmodel numbers and will you be connecting it to our DISH equipment.
Oct 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
My tv is actually a 42pfl3603d/f7 , had it for one year, the picture is green, but i can hear sound. what could be the problem?
Ur Tuner signal board is dead.Replaced this board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Philips 42PFL3403D 42 in. LCD HDTV
We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Apr 07, 2009 | Philips DVP3960
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Philips 42PFL3603D 42 in. LCD TV Logo
334 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
