Question about Maytag MER6772 Gemini Electric Kitchen Range
Hello there, i have an older model of maytag electric stove, there must've been a power shortage @ 0200AM this morning and ever since there's this alarm that keeps on beeping and for the life of me, i could not figure out to turn the thing off and reset my clock, it keeps on flashing Fo1
  • Anonymous May 07, 2009
    f-1 alarm keeps going off, it will cancel but only for a little while
    Genius:
  • 1,605 Answers
Here is the link for the users manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113P363-60.PDF
good luck
Posted on Dec 01, 2008
Plug on stove not working
Try another connection , If still not working faulty cord or control unit.
Mar 25, 2016 | Maytag Kitchen Ranges
I have a Maytage electric slide in range with a ceran top. Model number MES5770ACW. I was cooking dinner last night on my stove and the elements on top stopped working. They will not turn on at all even...
Either control board bad, or there is more then one circuit breaker controlling the power, check the breakers on both the inside and outside breaker box...Stranger things have happened..
Sep 10, 2017 | Maytag MES5770 Electric Kitchen Range
How to clean glass cooktop maytag electric Model
Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
Joe
May 07, 2010 | Maytag MEC7536WS Cooktop
I GOT THE BURNER IGNITOR WET WHILE CLEANING STOVE...IT KEEPS CLICKING...WHAT DO I DO
It will stop once it drys out. The best bet is to unplug the electrical power cord and let it dry overnight. Plug it back in the morning and it should be fine. The moisture is most likely in one of the switches just behind the knobs.
Apr 21, 2010 | Maytag MGR6772 Gemini Gas Kitchen Range
Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Aug 02, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Oct 16, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Replacing smooth top
You said, you broke the top of my stove - how do i go about replacing it? I have a maytag smooth top stove I don't have the model number its torn off the stove was here when I moved in and now its broken and has a big crack in it how do I get a replacement please help.
This is more than likely your ranges model # MER6772 Gemini Electric Kitchen Range
Maytag will be able to replace the top once they come out!
Below is the info and help you asked for!
Thank You , Huuum
Please remember to leave a solved rating before you leave!!
Here is what you asked for!
Call the dealer from whom your appliance was purchased or call Maytag Appliances
Sales Company, Maytag Customer Assistance at 1-888-462-9824, USA to locate
an authorized servicer.
Be sure to retain proof of purchase to verify warranty status. Refer to WARRANTY
for further information on owner’s responsibilities for warranty service.
If the dealer or service company cannot resolve the problem, write to Maytag
Appliances Sales Company, Attn: CAIR® Center, P.O. Box 2370, Cleveland, TN
37320-2370, or call 1-888-4Maytag for PriorityOne Service (1-888-462-9824).
U.S. customers using TTY for deaf, hearing impaired or speech impaired, call
1-800-688-2080.
NOTE: When writing
Oct 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Aug 22, 2008 | Maytag MER5775Q Electric Kitchen Range
MER5730AGW Electric Range
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Aug 14, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
197 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
