Question about Linksys BEFSX41 Router (DHBEFSX41)
No internet access out of router
I have internet access directly out of the cable modem but lose access when contecting to the router.
  • 65 Answers
Some ISPs require you use a known MAC address. This is a setting that can be adjusted on your router. This link should walk you through the troubleshooting sequence. If that doesn't help you, then this other link will take you through a number of different possibilities. If all else fails here is a list of customer support phone numbers
Posted on Nov 28, 2008
Problem cisco EA6500 to i-cable router HK
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Apr 21, 2013 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
Problem cannot to i-cable router
Apr 21, 2013 | Linksys by Cisco Linksys EA6500 Smart...
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I need to reconfigure my ativa wireless router as i just had to replace my cable modem from my internet provider at&t. i can't find my original paperwork as i recently moved my business. everything...
If you recently replaced your cable modem, it is most likely that your cable modem is setup as your router. You will need to access the cable modem directly and have it set to bridge mode where it only passes the straight signal to your router.
Most people do not use an external router so cable modems are automatically set to be the router as well, thus making them a Gateway modem. The commands to do this sometimes are not available on the regular login and you might have to have a tech login under their special credentials which give higher access levels. Your router should simply start to work fine once this is done because the cable modem will disable all routing and firewalls and leave them up to your personal router.
If you plug in a laptop directly to the cable modem and can access the internet, google whatsmyip and find out if your IP starts with a 10 or a 192. If it does, you have verified that your cable modem is doing the routing and needs to be changed to bridged mode.
Jan 15, 2018 | Office Depot Ativa 802.11g Wireless...
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
When I hook the etherton cord from the cable box to the Linksys router I loose all intenet contection. The only way I am able to access the internet is plugging the cable modem wire into my laptop. Any...
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
You can do it manually without the CD.
Click Here for step by step by instructions
Jan 26, 2010 | Linksys Wireless-G WRT54G Router
I can access internet direct. But no internet Model dir 615
Whilst the router is turned on, try to reset the router by pressing and holding the tiny reset button at the back of our dlink router using a paperclip. Then try again.
Jan 02, 2010 | D-Link Computers & Internet
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Linksys BEFSX41 Router (DHBEFSX41) Logo
193 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
