Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Burners light ok, oven will not light
My wife cooked pies ok Wed. morning. She then used the self cleaning function with no problems. All in the A.M.. That evening she tried to light the oven to bake cookies for Thanksgiving, the oven wouldn't light. The stop TIME KNOB is pushed in, She has never used this function before but I checked it to eliminate that possibility. Our oven is a Kenmore Model # 911-7398510 Serial # 5164308. Purchase date 6-10-1985. The previous owner kept the Owners Manual,Bless her heart. Please help with any suggestions. Is there a way to test the ignitor? I have some electronic troubleshooting knowledge. I can't afford new. Any tips or hints greatly appreciated!!!! Thank You.
  • Ken Bledsoe May 11, 2010
    The ignitor can be checked with ohm meter should have resistance.
    Sergeant:
    Champion:
  • 311 Answers
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Hotpoint SD97PI oven self cleaning funtion and grill not working
    The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
    Jun 22, 2012 | Hotpoint Ovens
    Dacor Preference RSD30 Gas Range My wife put the
    I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
    Regards,Richard
    Oct 17, 2011 | Dacor Ovens
    Stove top want heat up
    the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
    Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    My oven will not heat up at all.
    make sure your cooking timer is on manual....
    Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
    Not enough gas to range?
    you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
    Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 24, 2008 | Frigidaire 27 in. Electric Double...
    Frigidaire Gallery Professional Series - No clock/oven functions
    i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
    Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
    The right front burner won't heat
    The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
    May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
    216 people viewed this question
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
