Question about Protron PD-758LP
Screen does not work.
When I remove the dvd player from the case, insert a disc, and turn it on the screen does not respond.
    Problem Solver:
  • 22 Answers
I had the same problem on my Protron PD-758LP. What the problem was with mine, is that the switch on the back was set to "IN, it should be set to "OUT" when playing DVD's.
Posted on May 31, 2007
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
It won't play a dvd! and when it does it just sits like it is stopped!!
Hello
Eject the DVD from the Cyberhome DVD player. Look over the bottom of the disc. If any dirt and fingerprints are present, remove them with a damp cloth, moving from the inner circle of the DVD to the outside.
Insert the DVD into a scratch repair device, if the DVD has any light scratches (deep scratches are not reparable). Turn on the DVD repair kit and the device literally sands down the scratch. When this is finished, the DVD should work correctly with the Cyberhome DVD player.
Avoid inserting homemade DVDs into the disc drive. The Cyberhome is not compatible with many self-created DVDs, causing a "Disc Read Error" message to appear on the screen.
Spray compressed air into the disc drive of the DVD player. The compressed air removes dust and other debris from the laser and reading lens in the player.
Apr 25, 2011 | Cyberhome CH-DVD 300 DVD Player
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
This sounds like your Sony player is not reading the disc.
I have bought faulty DVD discs before that have given this same fault!
- I assume you have tried a disc that you know works in another DVD player?
Remember, your Sony Blu-Ray should be able to play ALL REGIONS of standard format DVD discs, so you should get sound & images from any one you choose.
Nov 06, 2009 | Sony BDP-S350 Blu-Ray Player
Partly Frozen DVD player that is unresponsive
HELLO
OK! try plugging the unit back in to the mains power and bring it out of standby (if you can) and press eject. If nothing happens - don't panic!
Unplug it from the power and remove the lid off the machine. Where the disc is you will see what is called the disc clamp (this bit holds the disc in place when playing).
it's made of plastic and there should be TWO visible screws (one at each side) they may have black rubber stoppers over them. Take off the stoppers and remove the screws and the disc clamp will just simply lift off and it's very easy to replace as well.
There may even be a place on the bottom of the unit where you can insert a hair clip or something to release the mechanism.
Hope this has gone some way to help you (:-)
Oct 05, 2009 | Cyberhome CH-DVD 300 DVD Player
When disc inserted it says that no disc is in
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 25, 2008 | Televison & Video
Disc is not being read,not spinning
Apr 21, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Appears a blue screen and lost all controls
Sounds like a thermal related problem (it's getting too hot). There's not alot you can do since it's likely a design flaw that is at the circuit level.
Sep 21, 2007 | Delphi MV10021 Car DVD Player
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
Protron PD-758LP Logo
43 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
