Uniden DXI-986/2 Cordless Phone (dxi9862) Logo
Anonymous Posted on Nov 28, 2008
Toshiba SX-2108 cordless phone won't ring if it's on the charger
My Toshiba SX-2108 900MHz cordless phone has always worked flawlessly until about a month ago - when it decided to spop ringing if it's on the charger..It rings when it's off the charger though. Any ideas about what's causing this and how to fix it?
3 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Oct 25, 2008
SOURCE: phone rings 6 rings before voice mail picks up
Sure. If you had bothered to mention which model you have.
The same internet where you found fixya can also be used to find memorex.com.
How about this? http://www.memorex.com/manuals/MPH6990-03OM.PDF If your model is the 6990 or close, you press MENU 3 times and can set the rings to 2,4,6,8 or tS which answers on the 4th ring if you have no messages or 2 rings if you do.
Carl
Anonymous
  • Posted on Dec 17, 2008
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Anonymous
  • Posted on Jan 22, 2010
SOURCE: how to change number of
phone 390 ringer does not work during power failures
Re: Panasonic KX-TC1402 900MHz cordless phone ..... Had "recharge" indicator showing. Replaced battery and seemed to work OK for a couple of months (until the new battery ran down?). Now the...
I had this phone for awhile. finally connected and it worked for awhile. I unplugged to move to a different room now it doesnt work. The in use light does not work.
I have a UNiden 900mhz extended range and lost the guide for resetting modes, time, number of rings, etc. Can you give me a quick guideline?
just look up online Uniden cordless phone Owner's Manual 2.4Ghz model EXAI 2224 series. It's free and lists all the commands needed for your Uniden 900mhz phone. page 1 to 68 just like the same one that came with the phone.
5helpful
Wifi interference??
The short answer is that it could interfere with the wi-fi, but your wi-fi should not interfere with your phone because it uses WDECT, "wide-band digitally enhanced cordless telecommunications" engineering. No matter how tight the bandwidth is on any RF transmission, power, proximity, and harmonics all play a roll. Ideally we want the power from our transmission to occupy the target frequency but the reality in RF is that this is nearly impossible without DSP filters. I have pasted some extra info below to help answer this question.
Digital Enhanced Cordless Telecommunications
(DECT), known as Digital European Cordless Telephone[1] until 1995, is an ETSI standard for digital portable phones (cordless home telephones), commonly used for domestic or corporate purposes. It is recognised by the ITU as fulfilling the IMT-2000 requirements and thus qualifies as a 3G system.
The four most common frequencies today are 900MHz, 2.4GHz, 5.8GHz and DECT 6.0:
900 MHz Currentlythe most common frequency for cordless phones, 900MHz phones may offera greater range than other frequencies. However, the 900MHz spectrum iscluttered and may result in interference with baby monitors and other900MHz cordless phones. Radio scanners can also easily pick up thisband. 2.4 GHz 2.4GHzphones offer better clarity and security than 900MHz, but mayexperience some interference with microwave ovens and wirelessnetworking (wi-fi) products. 5.8 GHz Themost advanced cordless phones available, 5.8GHz phones transmit on anew, open frequency and have the least chance for interference. Theywill not interfere with wireless networking (wi-fi) products. DECT 6.0 DECT6.0 operates on the 1.9GHz frequency. Though newly approved in the US,this frequency has been used for many years in Europe and can increasecall clarity and security. The wi-fi friendly DECT technology easilyintegrates into homes with wi-fi and internet services because the1.9GHz frequency is exclusive to DECT, making it interference free forcordless communications.
1helpful
2answers
Phone rings 6 rings before voice mail picks up
Carl
3answers
Bellsouth 9915 Manual
Amazon. com has the manual:
http://www.amazon.com/BellSouth-MH9915BK-900MHz-Cordless-Phone/dp/B00005U23W
6helpful
Handset microphone volume low
Uniden 900MHz cordless phone can hear ringing. When I pick up the phone, volume is very low, hardly hear other side. Volume controls do nothing to raise it.
My email: [email protected]
Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
