Question about Toshiba Satellite A75-S206 Notebook
Location of Screws
A75 S206 I installed a new power jack and it works fine However, I did not properly make a note as to the location of the 2 longest screws . CAN you advise where they belong?
  • 64 Answers
If there are only 2 long screws they will most likely only be able to fit into 2 spots, trial and error at this point.
Posted on Mar 05, 2009
No start after reassenbly to clear cooling fans. lights come on. no fans when start is pushed no action at all.videoed disassembly to insure correct re assembly according to toshiba A75-S2131 specs by
A) You did use an ESD wrist strap, and have it's alligator clip attached to a good ground source, right?
That way you don't have to worry about Static Shock issues, and frying out your laptop.
No?
You may have an expensive paperweight now.
(Although the motherboard does make a pretty good Frisbee)
Use any type of Anti-Static Precautions?
You did Follow Anti-Static Precautions? Good. Let's go on.
A) DC Power Jack
http://www.ebay.com/itm/DC-JACK-POWER-PORT-TOSHIBA-SATELLITE-A75-S2131-A75-S206-A75-S2061-A75-S276-/270935761721?pt=Laptop_Adapters_Chargers&hash=item3f1507a339
Not advertising, using for reference. (Photo views)
1) Battery removed check the Center Pin of the DC Power Jack. Does it move?
2) Cracked solder joints of DC Power Jack to motherboard?
Yes, means disassembly again to check.
B) Cables (Wires) are routed SPECIFICALLY through Channels and Latches.
1) Are they, or is one or more pinched by being in the wrong place?
C) Power On button board's FFC installed, in the SAME direction as when it came out? Lock Bar in place to keep FFC locked in?
FFC = Flat Flex Cable.
As you know it has no connector on the end. The motherboard has the ZIF connector. Zero Insertion Force.
http://en.wikipedia.org/wiki/Flexible_flat_cable
The flat contact pins of that FFC has to line back up in the ZIF connector on the motherboard, the same way it was when removed.
Broke the Locking Bar on the motherboard's ZIF connector, or the Body of the ZIF connector?
You're looking at motherboard replacement.
Post back in a Comment with your findings.
Regards,
joecoolvette
Aug 17, 2012 | Toshiba Satellite Computers & Internet
I cannot charg the battery I have toshiba satellite laptop A75-S206 ; and i can,t charg the battery tanks @ regard
Borrow a different 19V charger from a friend see if its just your charger if not then the DC jack most likely is damaged common issue with Toshiba and Acers. Good thing is Toshiba does not solder the DC jack it fits in a sleeve and plugs into the board.The Dc jack should run you around $5-$15 dollars the repair is a tare down to the boards right corner. Look on utube for "A75 tare down" should be a video floating around show you where the screws are. Shop would charge right around $100-$125 dollars if more they are ripping you off.
Oct 27, 2011 | Toshiba Satellite A75-S206 Notebook
Laptop shows 'A network cable has been unplugged" every 5 seconds
The Cable may have loose connect to the RJ45 jack get another good cable and it will work. Also make sure that the clip on the RJ45 jack as not broken and make it click when you connect the jack to the Network port on your laptop
Dec 29, 2009 | Toshiba Satellite A75-S206 Notebook
How to remove motherboard from toshiba A75-S206
Go to this website and select http://www.laptopka.com/2006/03/18/taking-apart-notebook/ and select your model number on the left side of the screen. Follow the instruction that they provides.
Dec 05, 2009 | Toshiba Satellite A75-S206 Notebook
Will an A75-S206 power up on a/c if the battery is bad? Will it power up on a/c with out the battery installed?
Most laptops permit use from the charger alone even with the battery removed; I've used my lousy Compact for many months with the charging section for the batteries internally disconnected after it failed 2 months out of warranty. I'm a tech and knew how to disable the charger since I didn't use it much while under way anyhow.
Aug 13, 2009 | Toshiba Satellite A75-S206 Notebook
Toshiba
Most likely needs the DC jack replaced as these are the same Singatron jack HP recently settled out on for class litigation. We've replaced thousands....
Sep 01, 2008 | Toshiba Satellite A75-S206 Notebook
Toshiba Satellite A75-S206 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
