Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Elite soap door problem
Cycle runs normal but at end door on soap dispenser is still closed and soap tab is intact. Using Electrosol super tabs. Could they be too thick, causing door to jam? They are the ones with the ball of "jet dri" in the middle. Please comment
Thanks, Kevin
    Sergeant:
    Champion:
  • 311 Answers
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
Posted on Nov 28, 2008
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
yes it will foam up unlike you have never seen before
by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The soap remains inside the dispenser, thus door opens up, but soap remains inside....just drips down the door.
What you have is a faulty cycle timer. Replace this and your dispenser will dispense the soap when prompted.
Mar 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
My Kenmore Elite dish washer's soap door doesn't open during when I run the washer
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 09, 2009 | Kenmore Elite 45986 Front Load Washer
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap Dispenser Problem with Kenmore Elite Dishwasher
its possible to have a faulty dispenser, but i would look for other reasons first. Im a big powder user and proponent. powder just breaks down better in hot water.Have found that by using the tabs(whoch im sure the gel packs could give same issue) that they dont really fitting the dispenser as well they're a little tight to close the door and the spring action of the dispenser is sometimes not enough with te extra pressure from the tablets.also ck to make sure youre loading it correctly and nothing is blocking the water form spraying into the cup fully emptying it
Mar 22, 2008 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
152 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
