Question about Honeywell Programmable Thermostat Heater
Blower on Carrier Crusader Gas Forced Air Furnace problem
I have a 1989 Carrier Crusader,58ssc
The blower motor sometimes will not work. It hums loudly.
If it is turned off for an extended period of time it will work again.
I have replaced the capacitor and it works somewhat better, but will still stop as before. Should I replace the motor?
One other problem, removing the control box to access the motor.
There is a strip of wires that connect to the control box circuit board thru a opening in the sheet metal frame. How best do I disconnect this. After the removal, it is a simple job. Have the furnace manual, but no instructions on how best to do this task.
  • 1,420 Answers
You have a system that is 20 years old. The cost of the repair may be 1/2 of a new unit. This unit will continue to fail and only cost you more that you can expect to get out of it.
Posted on Nov 28, 2008
Carrier furnace 58ssc130-LC blower will work sometimes
Likely a problem with one or both relays on the circuit board. When the motor does not start up with a meter you must determine where the voltage stops, therefore preventing the motor from running. Best Wishes.
Nov 23, 2017 | Carrier Heating & Cooling
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
The air conditioner unit outside works fine but it does not blow any air in the house.When it wants to blow, it makes a humming sound only but no forced air movement. Also,how do I access the blower,...
On the Good man you need a 5/16 nut driver take the furnace panels off and the blower is in the bottom area. There are 2 screws up top that connect to the blower housing take those out. Everything else will be loose be careful with the wires they can be tricky to work around. But take your motor out throw it away and install your new blower motor and capacitor. Its a simple job really. If you replace the motor yourself you willl save over $300.00
Jul 06, 2011 | Goodman CKL49AR49 Air Conditioner
My Carrier 58WAV136 forced air heater's problem is as follows - Thermostat works fine, when desired temp is reached, the fan motor (blower) kicks on. Sometimes it stays blowing for a couple of seconds,...
There should be a code list inside the furnace panel access door. Find it and see what code 41 says, as I can't remember right off hand. Some of the possible causes could be air in gas line or low gas pressure. Could have blocked vent especialy if vented with plastic. Check for bird nest or dirt dobbers in vent. If vented with plastic could not have proper rise 1/4 per foot and have water trapped in pipe blocking vent. Is this a new problem or has this occured since installation?
Oct 07, 2009 | Carrier Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
1,635 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
