Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Buttonholes When making bottonholes, it will not make them properly. Maching keeps going does not stop. I have turned the dial to reset the machine and will not fix problem
  • mary quindry Jan 28, 2007
    I still have not resolved the problem. PLEASE HELP
  • Kenmore Master
  • 1,388 Answers
Can you do an ordinary reverse stitch, if not, the reverse mechanism may be jammed, that will need some further internal exploration,
BUT, if you can, then:
The sensor arm that pulls down from the machine needs to be between the carriage stoppers, this tells the machine how large the button is, therefore, when to change direction.
The Kenmore is similar (same?) as Janome I believe and so should be very similar to this image.
Ensure that the sensor arm is pulled down between these two plastic stoppers at points maked with red, if the arm is at the rear of stopper, it will not do the cycle, just continue.
Only reset the machine after each completed buttonhole, if reset in mid cycle you will be starting a new cycle before it is time.
Do a couple of tests on some scrap fabric before you commit.
Bargain Box
Posted on Jan 30, 2008
I cant get the auto bottonhole attachment to work. I have follow instruction book. Nothing!
Here is a list of YouTube videos showing Singer machines doing Buttonholes:
Google
Mar 08, 2015 | Singer 6423 Sewing Machine
I can not get the automatic button hole to work properly on my Janome 6019.
Hello what is the machine doing
for example i have a 5018 with mine there is a lever at the back to pull down which when it finishes half it stops and resets itself to complete the other side and stops when complete but need the button in the compartment to guide for sizing
i will do a video clip on my channel send more info to mysteria21@gmail.com
Feb 25, 2015 | Janome Sewing Machines
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
Machine beeps and won't sew when buttonhole foot is attached - I have followed directions very carefully
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
Dec 12, 2009 | Singer 7462 Mechanical Sewing Machine
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
Oct 14, 2009 | Husqvarna Viking 1
I have a confidence 7470 and I can not get my machine to sew because the error sigm says I need to lift my bottonhole arm back up. I have done this repeatedly and have turned the machine on and off to...
It is the switch that is connected to the arm that may not be working properly which in turn send the wrong signal to the display.Check the arm and look for any kind of switch connected to it..Try to move it and see what happens or if the error disappears..
Sep 02, 2009 | Singer 7436 - INGENUITY
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
Apr 07, 2009 | New Home MX-3123 Computerized Sewing...
Buttonholing - Bernina 950 (semi-industrial)
This sewing machine looks exactly like the Berninas that I own, although my are not industrial. You just use the dial to make each side of the buttonhole, only having to set the stitch length to super small. The way you make buttonholes is this:
Think of the buttonhole as a square-ish capital O, with the center of the bottom of the O as the point where the button shank will lie when buttoned. Place the marked buttonhole area under the buttonhole foot, with this bottom point directly under the foot, squarely in the center of the 'hole'.
-Turn the dial to 1 and the long left edge will sew in zig zag stitches; stop the machine at the top of the O.
-Then turn the dial to 2 and the top edge of the O will sew; stop the machine after half a dozen stitches.
-Turn the dial to 3 and the right edge will sew; stop the machine at the bottom of the O.
-Turn the dial to 4 and the bottom edge of the O will sew; stop the machine after half a doze stitches.
-Turn the dial to 5 and run half a dozen stitches; this is a line of straight stitches that will 'tie off' the buttonhole.
Try this with a plain piece of fabric. Just put the fabric under the foot and dial away. You'll see how the stitches stitch.
I'll send a copy of instructions from my manual to you if you want. Email me at: pink8006@yahoo.com.
Sep 05, 2008 | Bernina 2500DCET
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
222 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
