Question about HP Compaq Presario R4000 Notebook
Laptop DVD/RW Drive
I have a problem with my DVD/RW drive on my Presario laptop. Some a month ago, my laptop stopped recognizing the drive. As the problem arose, l check the Device Manager, the driver is not listed there,l try all possible best no way out, l try to reset the BIOS and even update the BIOS, the same proble,l know remove the driver and refix it back again and the drive started working again and all was fine. Then, two weeks later, the drive stopped working again, meaning I cannot use this drive at all. Though disc drive is still getting power, and I can open and close the drive without problem, but it is not recognized. Please is there any urgent solution to this problem? Thanks for your help!
  • 624 Answers
Hi takino, Sounds like you have a faulty connection between your drive and the laptop or you drive has some serious problems. The first thing to try is reseating your DVD drive as follows: -Flip the laptop over with the front of the laptop facing you. -The DVD drive should be on you right. Towards the right center there is a single screw that secures the DVD drive to the laptop, remove it. -Insert a straightened paper clip into the release hole just underneath the DVD eject button on the DVD tray front. The DVD tray should eject. - Use the DVD tray to pull the DVD drive out of the laptop. It shouldn?t take too much force, but it might be snug. -Pull the drive out and look inside the bay. Clean any dust or foreign material in it or around the DVD connector in the bay or the drive itself. -Reinsert the drive and replace the screw. -Start the laptop and test. If that doesn?t work I would suspect your drive is probably damaged. If you are lucky and know someone with an identical unit you can swap drives and see if the problem follows the drive or stays with the laptop. If the problem stays with the laptop you probably have a motherboard problem, if it goes with the drive then you have a bad drive. Replacement drives can usually be purchased relatively inexpensively on Ebay or other parts supply houses. Motherboards, however, tend to be more expensive and are far more complex to replace. Let us know if you have another questions and please don?t forget to rate the posting.
Posted on Jan 14, 2007
CQ61 SATA Laptop AD-7561S DVD/RW CD/RW Driver
reinstall your catalyst drivers from the ati website, there is also a M$ fixit for your CD/DVD drive located here http://support.microsoft.com/gp/cd_dvd_drive_problems good luck!
Feb 11, 2012 | Compaq Presario Notebook
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
DVD-RW Not recognized in Dell Inspiron 1525
Turn off your laptop, take the dvd-rw drive out of the laptop and then reseat it back into the slot so it snaps into place. Turn the laptop back on and make sure its recognized in My computer.
If it is reocognized then try to burn again and see what happens. If it still gives you the same message, see if your drive will read regular dvd movies. If it doesn't then that means the laser is going bad and the drive will need to be replaced.
May 18, 2009 | Dell Inspiron 1525 Notebook
Laptop CD/DVD Drive
I think buying a USB DVD drive is a very sensible idea as internal drives on laptops can be a pain to remove and fit and they are more prone to failure than their desktop brothers because of their flimsy construction.
Jan 01, 2009 | HP Compaq Presario V6000T Notebook
Laptop CD/DVD Drive
Hi RC2935
Try this and see if it will help you
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Computers & Internet
Laptop DVD /RW Drive
did you try a dvd cleaner some times the laser inside gets dirty and then it will not work if this does not work try a different dvd player in it a little serect is to try a different one always if still does not work might have to redownload the drivers for your computer on your computers website ..
Jul 14, 2008 | Computers & Internet
Laptop restarting
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Jun 14, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
This is a duplicate posting, an answer appears on this link: http://www.fixya.com/support/t130491-laptop_dvd_rw_drive
Jan 14, 2007 | HP Compaq Presario R4000 Notebook
Laptop CD/DVD Drive
You might have to buy a new CD/DVD drive they are farily easy to mount all you need is a phlipshead screwdriver.
Nov 18, 2006 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
