Question about Toshiba SD-4800 DVD Player
The disc tray on my Toshiba Sd-4800 DVD player will not open
I have tried the open / close button on the front of the DVD player and the remote open / close button. I have turned the DVD on and off and even unplugged and plugged it back in but I can't get te DVD insidfe out.
  • 1 more comment
  • wjburris1959 Feb 03, 2009
    same problem!!
  • nicksque May 05, 2009
    Same problem. I get a "disc error" message on the display although I just watched the movie the previous night and have taken the cover off and can see the disc is in fine condition. Is there anyway to retrieve the disc without dis-assembling the dvd drive itself?
  • phobio May 25, 2009
    Me too. With no disc inside. Won't open. Window alternates between closing...opening...insert disc. Player finally turns itself off.
SOURCE: Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Posted on Aug 19, 2007
  • 6 Answers
SOURCE: Trouble with the disk tray
had the same prob with a sony dav dz it kept saying locked but after hours and hours of pressing random combinations it came off im sure it was unplug plugback in then hold power and open tray and tap stop or a combination of those buttons.i woud try it again on mine to make sure but i do not want to lock it again.
Posted on Nov 19, 2007
romsky79
  • 822 Answers
SOURCE: Toshiba SD-3980 DVD player not working
check and clean dvd lens. change lens if same problem.
Posted on Jun 02, 2009
  • 35 Answers
SOURCE: DVD disc tray will not open
Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
Posted on Jul 31, 2009
  • 347 Answers
SOURCE: I have an RC100H that keeps opening the DVD/CD
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Posted on Feb 21, 2011
Tray won't open. I have a library disc in the tray. How do I get the disc out.
Look to see if there is a tiny hole on the face of the tray, if the tray door has a pin-hole, you can use a straightened paper-clip.
Push the paper-clip into the hole...causing the tray to open.
Also, Try holding the eject button while turning it on.
Dec 29, 2014 | Toshiba SD-4800 DVD Player
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
What is the region code for toshiba SD-K750 DVD player
hello,
Pressing the Open button on your remote control to open the drive tray, Press the 2403960 button on your remote control
region 1, 2 for region 2, and so on, or 9 for multi-region playback, Press the Open button on your remote control to close the drive tray, Power off the DVD player, Power on the DVD player
Report this hack (requests/questions/spam/wrong/****).-->
Jan 04, 2010 | Toshiba SD-K741 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Toshiba SD-K760 region codes.
I found this on another site, worked for me, hope it helps...
icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
2. Press the 2403960 button on your remote control
3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
4. Press the Open button on your remote control to close the drive tray
5. Power off the DVD player
6. Power on the DVD player
Jan 17, 2008 | Toshiba SD-K760 DVD Player
Toshiba SD-4800 DVD Player Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
