Question about RCA 27F530T 27" TV
Can i put my tv on input without the remote - RCA 27F530T 27" TV
  • wannanewtv Dec 05, 2008
    tv will not switch to video so as to allow me to view cable or any other video input devices, it has a tv/video button physically on the tv but even that doesnt switch it? can anyone help me?
If your tv's front panel isn't working at all and the remote isn't either, then there is a simple fix. The only thing is that you will only be able to control your tv with the remote only. You can disconnect pin 4 at the connector of P001B on the front control panel circuit board. That will disconnect all the tack switches but allow the use of remote. First take your tv rear case off (there is 3 small torx head screws on the rear input/output panel, remove these first. Then there is two torx head screws on the left, top, and right side of the case facing rearward and connecting the black rear portion to the front silver portion). Once the rear case is off, there will be the front control panel circuit board attached in the front of the tv that needs to be unscrewed. Once unscrewed you can see all the connections labeled with eithers words or numbers. On the P001B connector on the front panel circuit board, there will be a 1 on one side and a 5 on the other. The pin 4 is naturally directly to the left of the 5 pin. There will be a bundle of wires leading from the front control panel to the main board of the tv which is on the bottom of the tv. Disconnect this from the main board. Then follow the #4 pin wire all the way from the front panel circuit board, to the connector end that you disconnected (This will be easy b/c they are in a flat bundle side by side). Then just completely remove only the #4 pin connector wire from the connector end. Wrap the end in electrical tape, plug the connector end back into the main board, and put the tv back together and it should work fine with the remote only (the front panel buttons will no longer work).
Posted on Dec 17, 2008
No remote..want to play xbox...how can i do this without remote? TV has no input button
Just get a cheap universal remote, and program it to the TV. Some TVs don't have the dedicated buttons to switch inputs, without the remote.
Jul 10, 2012 | Televison & Video
Need to change input, no remote
There is no way to change the input to this set without its remote control.
Apr 12, 2012 | RCA Televison & Video
Techwood 42in tv model 42832 hd digtal it turned itself of,cant get no picture,but blue stand by switch still turns on and off
It sounds like your TV's display has been routed to a different INPUT than the Cable/TV input jack, like a VCR in put or an RCA input. You need to change the input back to TV from VCR or LINE1 or RCA, so on. How to do this without the original remote, you are going to have to look up the program code for the universal remote and program that remote correctly, once done, change the TV Input until you're back on cable.
Mar 29, 2011 | Televison & Video
I am trying to change the input on my tv but I do not have a remote. Can I still change it? How?
on some tv's you can go back through the channels and it will get to AV (eg: 2,1,0,av1,av2,99,98...)
Some TV's will have an AV or input selector buton on them
and on most TV's you cant put it to AV input without the remote... you could try a "0ne for all" remote, they generally work and are cheap
Aug 27, 2010 | Durabrand DWT1905 TV
Without the remote how di I get to the game input on the TV?
do you have a cable remote? if so put on aux and hit every key on remote it may trigger game input usually the record key will be the input button
Jun 11, 2010 | Symphonic ST4913 TV
Emerson TV input option
Tries the channels + or - buttons a couples times on the tv manual controls buttons on the tv.U will get in the input option.This solution work for many tvs don't the input option on their universal remotes,without the original remotes.Ur tv don't know.
Jun 02, 2010 | Emerson EWF2704 TV
INPUT MODE WITHOUT REMOTE
Hi
If you cannot reach the AV input mode by scrolling through the channel up down, nor is there is a source or TV/AV button on the set it self, then the news is bad I am sorry. You will need the remote to get AV inputs on this set.
You can get a new remote for the set from here for $1995. Plus postage. Note that it has the TV/AV button.
Happy to answer any questions you may have.
regards robotek
Apr 13, 2010 | Orion STV2763 27" TV
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
Is There a way to go to video/input without a remote.
My answer will be generic.
With many of these TV sets the original factory remote is required to change the input mode of the set, or to access any of the user menus.
On some models of sets, putting the channel selection down to below channel 2, puts the TV in to the external input modes.
Jerry G.
Feb 10, 2009 | Emerson Televison & Video
RCA 27F530T 27" TV Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
