Question about Dryers
How do you fit a dryer vent that has to go through the wall?
Unfortunatly you'll need to either knock, hammer and chisel, or drill, using a core drill, which you can hire from a tool hire shop, a hole through the wall. Then connect up the dryer hose to a vent kit which will fit in the hole in the wall.
You can buy the vent kits from most DIY shops and electrical shops (they don't cost much). This is the best way.
Alternatetivly you can buy a special filter box that the dryer hose fits into. This is best if the dryer isn't next to an outside wall. Again most DIY shops and electrical shops sell these.
Good Luck!
Posted on Nov 28, 2008
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Apr 09, 2015 | Dryers
Dryer vent connect
Yes, you can use a flex hose, however, remember there must be as short a connection between the dryer and the wall as possible, and you for sure do not want a kink in the hose. The flex hose can be cut to fit with metal snips. ( There is a metal coil inside the plastic)
Many poeople do not know about free flowing air from the dryer to outside, and so wind up with dryers that will overheat and/or not dry their clothers.
Be blessed.
Jun 23, 2013 | Amana Dryers
My dryer will not dry my clothes what should i do to fix this problem. It takes 3 cycles to dry a load completly
if its a condenser dryer make sure the condenser itself is not blocked up ( usually located at bottom of dryer, looks like a metal box). clear any lint build up and u can also flush it through with water. obviously check the filter also.
if a vented dryer make sure the vent hose not kinked or blocked, check the actual vent outside on your wall as wel. sometimes if wrong vent fitted ie one with wire mesh meant for extracter fan, can be blocked up with lint
Sep 25, 2010 | Kenmore Dryers
Just got a new tumble dryer with built in vent and hose. Trouble is i have a hose and vent already fitted to outlet (wall) in kitchen what can i do? Will i need to take out the whole fitting in the wall....
Take hose off the vent and then stuff plastic into the vent and take some drywall mud and fill the rest of the vent with mud. Doing that will keep criter out of you home
Jul 21, 2010 | Dryers
The sheetrock around the exhaust vent gets wet when running my Kenmore dryer. what causes this and what is required to fix it? The exhaust vent is located at the bottom of the dryer and goes through the...
This is steam moisture from the drying of your clothes. Check for a loose fit with your drier hose and the vent connection. You can try a refrigeration tape if needed. Also you can cover the hose with insulation, look for a metal film type.
Feb 27, 2010 | Dryers
We have to vent the dryer out the side as we have moved it to a new laundry room. How do we go about accessing the unit to do the same
If it is a conventional vented dryer, there should be an outlet for it, ususlly at the rear, or sometimes the side of the dryer.
It may have a blank plate fitted, which you have to remove.
You can do it by fixing a flexible hose to the outside, or it can be permanently vented with a proper through the wall vent kit.
Hope this is the information you are looking for.
Dec 08, 2009 | LG DLE5977 Electric Dryer
How far should the dryer vent be from the wall to the dryer?
No, you do not want the dryer vent crushed at all. Go to Home Depot and find a 4 inch adjustable 90 or something along that line. The problem will be that your clothes will dry for alittle while and then you will stat noticing longer and longer dry times
Feb 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Do I need an air vent through the wall for a dryer
If it is a condenser dryer, then you need no vent at all, as the steam condenses back into water, which is collected in the m/c\so you can place it anywhere.
If however it is a normal dryer, then it is advisable to have it vented.
You do not have to have it vented through a wall if you don't want to, you can hang the hose through an open window or open door,so long as the steam gets out of the dryer.
Obviously it is better if you can go through a wall, then you don't have any pipe to see, but it is not imperative that you do so..Hope this helps you..
Plz rate my suggestions .
Thanks, and a merry xmas.
Dec 20, 2008 | Dryers
Dryer's vent hose Problem
Wait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe. Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals. If your vent pipe is punctured or damaged, you should replace it.
Aug 27, 2008 | Elements of Design DS492 1/2" Inlet Copper...
LG TDC70080E
You have a plugged exhaust vent in the house wall.  Remove the vent from the back of the dryer and run the dryer.  The problem should go away.  You will need to call a qualified vent cleaning company to remove the lint restrictions inside the wall.
Mar 31, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
108 people viewed this question
Top Dryers Experts
