Question about OKI C3400n Laser Printer
Put a new toner in and it says toner sensor error and wont print
  • Anonymous Jan 19, 2009
    toner sensor error after new toner cartridge is put in
  • 3 Answers
I have indicated the solution in another post for C3400n. Basically on the right hand side of the drum there is a small rectangular opening of 0.5" x 0.25", ensure that the shutter in that opening stays open to allow the RFID chip to be read by the printer. The shutter may get jarred shut while changing the toner cartridge.
Posted on Jan 26, 2009
  • 27 Answers
Hiii,
what type of printer you use...model and what type of error it said...
Posted on Dec 08, 2008
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Dell 1600n I replaced the toner and can't get the "replace toner"
After you clear out the print que (double click on the printer icon on your desktop), power down the printer, wait 20 seconds and power it back up. The "replace toner" should clear after the sensor detects toner in the hopper AND the new chip in the toner cartridge registers with the "brain" of the printer. Hope that helps!
Aug 12, 2009 | Dell 1600n All-In-One Laser Printer
I have a Samsung that say Transfer Belt Error
hi guys.. iam Aqeel from pakistan.
i've just solved that stucking problem today and tellining u guys who are facing such problems over thr.
All you need to do are two steps:
1- detach the paper tray and push it back correctly.
2- open front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and left side of toner unit thr is a sensor door, behind that door there is also a light sensor bulb, which needs cleaning by a cotton bud.
thats all
i hope this will help u fixing that problem.
bbyee
Dec 21, 2008 | Samsung CLX-2160N All-In-One Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Sep 09, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Toner sensor error
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Feb 11, 2008 | OKI C5200n Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
OKI C3400n Laser Printer Logo
928 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
