Question about Polaroid Televison & Video
Polaroid PDM-0742 Model #BT-6005 with rechargeable battery pack: Unit will not power up when plugged into wall outlet or when using battery only. Please advise!
SOURCE: Polaroid DVD Player won't charge.
I had the same problem, which I attributed to having the plug in a power strip. Once I plugged it directly into the wall socket, I haven't had a problem since.
Posted on Jan 09, 2008
  • 104 Answers
SOURCE: new Haier 7.2V rechargeable NI-MH
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Posted on Oct 02, 2008
humanman42
  • 82 Answers
SOURCE: Good afternoon! My portable DVD
Clean the laser of the DVD player, clean the dvd, dont shake/move the DVD player while watching movie....
Posted on Dec 02, 2008
SOURCE: Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Posted on Feb 16, 2009
  • 303 Answers
SOURCE: i need ac adopter for my Polaroid PDM-0742 Portable DVD.
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID pdm-0742 pdm0742
Posted on Mar 05, 2009
I have a polaroid 8"
Hello
The battery you use may be new, but haven't enough current capacity to supply the DVD player. DVD players will take much more current in ampears. Check if voltage drops when your DVD player works. You can check it with the help of a multimeter, set to measure voltage. Fist check the battery voltage. Keep the probs of the multimeter connected to the battery terminals, switch on your DVD player, and check whther the voltage drops to a considerable rate. That is, if the voltage at no-load condition is 12VDC, it may go down upto 11.5VDC, and no more drop must be there. If it is so, make sure that the battery is bad. OK.
Mar 12, 2011 | Polaroid Televison & Video
DVD Player that repeatedly says NO DISC for Polaroid PDM-0752
either needs to be clean or the REGION needs to be set up to 1 or ALL , LETS TRY WITH cleaning the OPTICAL LENS with a dry Q tip , gently rub a few strokes at the lens , and give it a try, if NOT then try to set the REGION to 1 or all, if still not reading the disc , then have to replace the optical lens, good luck , AJ
May 28, 2009 | Polaroid PDM-0742 Portable DVD Player
POLAROID PORTABLE DVD PLAYER CHARGES ON WALL ADAPTOR BUT NOT ON CAR CHARGER
You can buy it at followig link:
http://recoupit.com/Portable-DVD-Players/c177182/
http://cgi.ebay.com/Polaroid-MPA-6930A-AC-Power-Adapter-9-5V-3-33A_W0QQitemZ140312970734QQcmdZViewItemQQptZDVD_Players_Recorders?hash=item20ab4e05ee&_trksid=p4634.c0.m14&_trkparms=|301%3A0|293%3A1|294%3A30
May 08, 2009 | Polaroid PDM-1058 Portable DVD Player
My polaroid pdm-2727m main player wont power up.
This unit has had a problem in the power supply and needs to be tested in a service center or by a experienced electronic technician for faulty power supply components. Hope this helps you with your problem.
Mar 08, 2009 | Polaroid PDM-0742 Portable DVD Player
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
No dislpay
1-866-289-5168 FOR ASSISTANCE. Try this number for technicial assistance on you unit. Hope this helps you.
Jul 08, 2008 | Polaroid PDM-0742 Portable DVD Player
Why my dvd player stopped working
1-866-289-5168 FOR ASSISTANCE. Try this number for technical assistance for you unit. Hope this helps you.
May 24, 2008 | Polaroid PDM-0742 Portable DVD Player
Lost remote
http://bestbuy.partsearch.com/
Mar 03, 2008 | Polaroid PDM-0742 Portable DVD Player
Oct 18, 2007 | Polaroid PDM-1058 Portable DVD Player
Televison & Video Logo
470 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
