Monitor Blinking My LCD monitor has been blinking (2 sec blank - 1 sec on) for a couple of days now. I connected the monitor onto another computer and it still blinked. I also fixed another monitor to the same computer and it worked fine. I changed the power code and switched off speakers and no difference. Any suggestion fix would be appreciated. I think this is a software or OS issue I have a KVM switch with 2 CPU in one I have WVU and the other has WXP. In the Vista CPU, the monitor blinks but in the XP CPU don't. Anybody can help.
  • SrFixer Nov 28, 2008
    Let me explain this, I only have one monitor attached via a Keyboard Video Mouse switch to two CPU, one with Vista Ultimate and the other with Win XP, then
    Scholar:
  • 44 Answers
HI SrFixer -
Since you were able to attach another monitor to the computer and it worked, that would indicate that the problem is not a computer problem but a problem with either the monitor or the monitor cable (data). Try another monitor cable on the monitor that didn't work and see if that works. If it still does not work, then I am afraid that your monitor has gone bad and needs replacing.
Hope that helps
Michael
Posted on Nov 28, 2008
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
My LCD monitor blinks after switch on the power. display appear and go blank again appears and go blank and again and again.......................
1. Make sure the computer is switched on.
2. Check to see if the monitor cable has bent pins.
3. Make sure the signal cable is properly connected to your computer.
4. The energy saving feature may be activated.
Thanks for choosing FixYa
Oct 11, 2010 | Philips 190B7CB LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blinking monitor
Ok well I think ya have a Power Supply problem with ya Monitor...
But to be sure try it on another PC see if problem follows, if NOT then maybe ya Video card is starting to bug out?
But I punt for the PSU in the Monitor.. As an aside check the Pins inside the Monitor connector see they are all OK
Jun 14, 2008 | ViewSonic VX924 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Monitor Blinking
hello guys
I had the same problem. My LCD ViewSonic VX 924 has been blinking
For repar it i changed the following capacitors : 100uF/400v
330uF/25v and 330uF/35v
if that always flickers you can also change the two 470uF/25v capacitors
The link for a pic Alime and Capacitors
http://img25.imageshack.us/my.php?image=alimefsp0351pi01.jpg
DO NOT TOUCH NOTHING D'OTHERS ANS DISCONNECT ELECTRICITY CABLE BEFORE PROCEEDING
Apr 08, 2007 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
667 people viewed this question
David Payne
David Payne
