Rca channel 13 and down are fuzzy grey and 14 up look great. Put an antenna with vhf and uhf from a working tv and still no go.RCA Model#G27666AT, Serial# 434450248, Chasis#CTC187BH, 1994
  • 4,234 Answers
This is typically caused by poor ground connections either at the cable input or inside the tuner itself. Check all external cable connections for good grounds. If those are good, then the tuner needs to be examined carefully for poor solder connections at the grounds.
Dan
Posted on Nov 28, 2008
I have an rca G36705 and I just need to know if it has a digital tuner or if o need a converter box to hook an antenna to it?
Its inputs include "Composite" and "S-Video".
Itttkk Its *ANALOG* tuner has channel coverage:
VHF:2-13, UHF:14-69, Cable:1-125, VHF:2-13, UHF:14-69, Cable:1-125
So, you will need a digital tuner.
So
Jun 05, 2015 | RCA Televison & Video
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
RCA HDTV antenna is it Ok on a non HDTV
Yes, this antenna will receive VHF and UHF signals. If you install it properly outside and point it towards your local transmitters, it will work nicely (use tvfool.com for the directions to your transmitters). The "HD" label is something of a marketing gimmick; the tuner on the TV will pull in the signal and interpret ito display on your TV.
However, make sure that you have an ATSC tuner for your TV. Only a few low power NTSC stations are still broadcasting.
I hope this helps.
Apr 15, 2013 | RCA Televison & Video
I have a wf24t5 that i want to connect to a dish sat hd. how and what do i need to do to connect?
After confirming by viewing the operation manual for this unit, this TV is only capable of inputting a baseband video and standard audio. Unless the Satellite Receiver you have has those type of output jacks then this TV will not be able to reproduce picture or sound from the Receiver. It may be possible to connect through the antenna connection but again the Satellite would need a connector that would output on Channel 3 or 4. Most recent satellite receivers do not offer these ouputs. You indicate that the Receiver you have is High Def. The TV you have is not high def and would drastically down grade the quality of your picture and audio being delivered by the satellite receiver
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
Feb 18, 2011 | Symphonic Televison & Video
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
RCA VCR VMT 385A support needed
c is cable
h is hi vhf (7-12)
l is lo vhf (2-6)
u is uhf (13 and up)
Dec 31, 2007 | Televison & Video
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
