Question about Epson Stylus Photo R220 InkJet Printer
Epson R220 has solid red teardrop light on - will not print.
The printer was printing fine and after a few sheets, it stopped when the solid red teardrop light came on. It remains on. Does this mean it is out of ink and how do I bring up the ink level chart which I cannot seem to find in the control panel?
I hooked up the printer to my old computer which has Windows XP. My new computer has Vista. The problem is with Vista as it does not allow me access to the ink monitor levels as is not the case with XP. This is one problem that I have noticed with Vista and would like to know if there is a quick fix for this. How can they put out a product inferior to Windows XP? There must be a download of some kind to fix this problem.
Posted on Nov 29, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson CX5500. 'teardrop' red light is lit up.
RESTART THE PRINTER , SHUT IT DOWN FOR 2MINUTES
Mar 29, 2010 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 print head goes left and then makes a grinding sound
Your printer needs a service reset. Epson printers will only accept x number of cartridge changes / print head cleans. Basically it's telling you that the waste ink pad is saturated. It will cost about £30.00 from a local service centre
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
I need to clear the inkjet heads on my Epson Stylus R220.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off. Access the printer software. Click the Maintenance tab, then click the Head Cleaning button. Follow the on-screen instructions. The power light flashes while the printer performs the cleaning cycle. Never turn off the printer while the power light is flashing. Doing so may damage the printer. When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Apr 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Espon Stylus Photo R210 solid red light near teardrop sign
most epson printers dry up after about 3-4 months so you will need to replace the cartridges and do a head cleaning about 3-6 times for them to work right. BTW the teardrop symbol means "ink".
press the button above the light for about 3 seconds to get it to move to the fill position. good luck!
Mar 14, 2009 | Epson Stylus Photo R220 InkJet Printer
R220 is not working
If you have done an ink replacement and you still get the lights.
you must download the newest reset tool.
CLICK HERE and go to the bottom of the page and agree to download file.
Sep 16, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Photo R220
epson printer R 230 flash how
Aug 29, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
378 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
