Question about Toshiba 52HM95 52" HDTV Projection Television
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
I have a 52HM84 DLP TV and I recently put a new bulb in. However, if I turn the TV off, the lights start blinking on the TV as if the bulb is no good and the TV will not turn on. After I try for several minutes up to several hours, the TV will finally turn on but now I am afraid to turn off the TV.
  • trebor57 Mar 13, 2009
    i have an lg 52sz 8r,i to recently replaced the bulb,with the same problem,after two or three attempts at turning tv on it stays on,and the picture is fine,would still like asolution,
  • 505 Answers
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Posted on Dec 06, 2008
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
Tip
Toshiba 52HM84 Manual Download
Toshiba 52HM84 DLP Projection HDTV Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV instructions.
I hope that helps.
_______________________________________________
Toshiba 52HM84 Service Manual Download
on May 14, 2010 | Televison & Video
Tip
Toshiba 52HM84 DLP Projection HDTV Service Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV Service instructions.
I hope that helps.
on May 13, 2010 | Televison & Video
Changed bulb and still no picture or sound
hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
May 30, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
on May 13, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
I have a 52" Toshiba
the ballast isnt keeping the bulb lit.
Mar 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52HM95 52" HDTV Projection Television Logo
1,394 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
