Question about Amana Refrigerators
Evaperatior pan dry. Water dripping into refrigeator. How do I clean the drain tube?
  • JEFF SIEGEL May 11, 2010
    Need the brand and model# please.
    Sergeant:
    Champion:
  • 311 Answers
What model# do you have
Posted on Nov 28, 2008
The small hole at the back of fridge keeps icing over how do i stop this from happening?
I usually use very hot water alil at a time onto the hole drain spout, and I have a soft long flexable tube that I insert into the whole ( the condensator) to clean out the blockage and debris. can use coat hanger but be very careful as can damage the tube drain line. unplug the drain line from bottom of drip pan and place towel under it, u can also try to blow into the flexable tubing down towards the drip pan if its not solid
Feb 16, 2015 | Kenmore Refridgerator Air Flow Diffuser...
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRIGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE...
Mostly the drip-pan can't be accessed from the front.
The drip-pan isn't.
It is in fact an evaporator. It collects the considerable amount of water from the auto defrost function and holds it until the heat from the motor and compressor can evaporate it. The water is transferred from the inside by a drain tube.
A blocked drain tube is not unusual and is generally fairly simple to clear. Often it is a stray vegetable that causes the trouble and sometimes it is a buildup of ice. If the water cannot escape a wet floor is usually the result.
Our fridge recently suffered from the same trouble. I used a plastic covered wire coat hanger to clear the drain of ice - very carefully...
Apr 27, 2017 | Refrigerators
My side by side drip"s
The water is from a blocked drain of the defrost, especially with the water off that's where its from. This tip i wrote will tell ya how to clear that drain http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaking water maytag plus rsw2400eam ...ice maker not hooked up. seems to be coming from freezer side can you help
When your refrig goes into auto defrost the water normally goes down a drain tube and into a drip pan under the refrig, then it evaporates. But now your drain in plugged somewhere and you will need to find it and clean it out. Hope this gets you going in the right direction.
Jun 05, 2011 | Refrigerators
I have an amana 18 top freezer that is about 15 years old. I am getting water on the floor of the refrigator, i have unplugged it for 24 hours, and it still does it. No water is in the pan. What do i do as...
No water in the drip pan, water in the refrigerator - this is a classic case of defrost drain issues. If your unit has a little drip cup at the back of the refrigerator (inside) you will notice a hole above it, this is the drain coming from the freezer - When defrost cycle kicks in the heating element melts the frost on the evap coils above it and water drips through the hole and inside your cup in your refrigerator - then it should drain through a tube that extends to the back of your refrgierator through a hole, from there water drips down the drain tube down the pan at the bottom above the compressor so it can later be evaporated with the heat.
What you have is a plugged drain tube - water drips in your cup and overflows down the back of your refrigerator - if you are able to remove this cup and tube, pass a long wire down the drain line to dislodge any debris or whatever is blocking the line - clean your cup and also check for any debris. Also at the back of your freezer panel look for any debris or obstruction to the drain, causing water to back up and leak elsewhere. Once all this is checked, and you put back the cup, water should flow normally and drain fast enough through the drain tube.
good luck
Sep 25, 2009 | Amana Refrigerators
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
Water drips from freezer into refrigerator
The drain is clogged..you need to see if it has a rubber drain trap going into the back side of refrigerator. if so, twist and turn as you pull it out and clean it..replace and then check that drain is open..if no drain trap on back side of refrig..remove freezer wall and open drain from inside freezer..you need to clean out drain trough using hot water..a little messy,but effective
Jul 12, 2009 | Refrigerators
Water leaking under refrig
there is a drip pan under the freg. check the drain hole at the buttom fo the freeze side. make sure it is open.
you can get to the drain pan via front grill. pull the front grill. and you will see the drain pan.
Nov 07, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
