Question about Daewoo DSP4210GM 42 in. Plasma Television
Daewoo Plasma DP-42SM Image "bouncing/scrambled"
Okay, so my uncle just gave me this tv last night because he was having problems with it. His boss gave it to him and had the starter replaced in it. But here is my experience with it last night trying to get it to work...
I plug it in and connect it to my Comcast Digital Cable with the composite cables. The screen is pink and green jigsaw puzzle. I turn it off with the power button ON the tv. (This turns the set completely off where as the remote only turns the TV off and puts it on standby).
So I turn it back on with the POWER button on the set and then on again with the remote. The image and color is normal but the image is shaking left to right. I repeat these steps and then I get that "unsubscribed porn channel" look where the color is off and the image seems to scramble when there is a lot of motion on screen. I also tried rolling through the different picture modes (Video 1, Video 2, Component 1, etc, etc) and when I got back to Video 1 the image is gone and left with nothing but a black image with some dark blue diagonal lines through it. Mind you the sound is working perfectly.
Anyways, can someone diagnose this problem from what I've described and, if possible, tell me how to fix it. (Whether is be myself or a professional) Not to be a bug, but how much would something like this cost to fix.
Thank you for your time and help!
  • David Shaub May 11, 2010
    You tried different video modes. Did you try different inputs?
What have a red image in the middle of our plasma tv what could it be and can we get rid of it
Hello nacoleray,
Does it look like a burned in image? If so and if you have a brand new samsung tv, it should a scroll bar that cleans out the screen. Go through the settings and this should fix it. If it is last years model or older you may not have this feature. Go to a channel that is snowy, scrambled picture and leave it on for couple of hours. This should some what make it better. If it is not a burned in image it could mean that you have dead pixels. Unfortunately this is not something you can just fix. I suggest contacting your manufacture. I hope this helps, if not give me a feedback. Good luck.
- Joe
Aug 31, 2011 | Samsung 50 in. Plasma TV
I have a daewoo plasma tv model dp-42sm with no video after taking back cover off found the x- sustain pcb with a burnt ic chip labeled iu4. after removing defective pcb and powering up tv set power stays...
I have the Daewoo Plasma Digital Dream model dp-42sm and it had power but no picture and my dads tv expert friend looked at it said the ysus board was out. I got the part on ebay for 125 dollars with 12 dollar shipping and put it in myself very simple and the problem is fixed. Is this the same issue your having?
Dec 17, 2009 | Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo 42" Plasma dp-42sm lines in screen
The problem is you have a cold solder joint on a component on the flex harness. My son will show you have to fix it on YOUTUBE. Check it out!
http://www.youtube.com/watch?v=EFpXYnGZCU0
Jan 14, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DSP4210GM 42 in. Plasma Television Logo
231 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
