I can not get the control lock off so I can do my laundry can some one help me? I have unpluged the machine, I have turned off the machine and tried to restart it again but it will not let me restart machine with another load. not sure how it got into the control lock mode.
Great help, thank you.
YOU ALL ARE GREAT THANKS SO MUCH IT WORKED FOR ME.. SOON AS MY HUSBAND GOES OFF TO IRAQ THINGS HAPPEN.. THANKS AGAIN AIMEE
Thank you. This worked.
I have run into that problem a few times and holding the cancel button or unplugging the washer did not work either. I found the only fix for that problem is to replace the control bord. You might want to call the 800 nuber for whirlpool because the electronics may be under warrenty. Hope this helps
Thank you. I was in laundry crisis mode as well and ready to call the repair man. End of cycle for 5 seconds worked for me too. thank you thank you!
Whirlpool customer support says, push the cancel button for 5 seconds, if that does not work, then unplug the machine for 30 minutes, if that does not work, then you will need a service call.... Neither worked, I found this post, pressed the end of signal button for 5 seconds and it works :) Thank you. Now why is this such a big secret??
That just worked for me after much online research. Good Fix!
Clearly a device to prevent children from turning the machine on. If you push the end of cycle button for 5-6 secs. It turns the control lock on, do it again, and it turns the control lock off, on both the washer and the dryer. Clever idea, if they bother to tell you about it.
Great advice. Thanks a million. Matt
Sounds like you have reset the electronic controller. Good one??
FOUND OUT HOW TO FIX PROBLEM . ON MY WASHER AT BOTTOM RIGHT HAND CORNER ,IT SAYS END OF CYLCLE SIGNAL. HOLD IN FOR 5 SECONDS AND IT WILL FIX ITSELF
My Duet Whirlpool Washer Control LLock Light is on and won't let me wash. Does someone know how to get it off Control Lock OFF!!
