Question about Apple iMac G4 Desktop
My iMac is not recognizing my CD/DVD-RW drive
I own an Apple iMac G4 that up until a few months ago was working fine. I am running OSX v10.3.9. When I put CD's or DVDs in, they do not show up on the screen or in the finder window. I am not sure if my daughter has downloaded something that has messed it up or not.
Any suggestions?
  • 55 Answers
Install your startup CD and restart the computer holding down the "C" if your computer starts off of it, the CD player is okay and you have a software problem, if does not start off the CD the CD/DVD needs to be replaced
Posted on Nov 28, 2008
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Safari doesn't work on this used Imac G4 I just bought, but Camino does work? How do I get Safari working on this old thing?
On the left Top of your monitor is a apple Logo.Tip on it and select "About that Mac" A Window pops up and you select "More Info" it shows you the OSX on it. OSX 10.3 or OSX 10.4 Google "Safari Browser for OSX 10.? " Download it and it will work. You may have the latest Version.
Oct 04, 2010 | Apple iMac G4 Desktop
I Have a MAC OSX 101.5 can I install leopard
Here are the minimum specs your Mac will need to run Leopard, from Apple:
  • Intel, G5, or 867MHz+ G4 processor
  • 512 megs of RAM (though if you only have 512 megs of RAM you should get some more. Trust me, I'm a pundit)
  • DVD drive (Leopard is shipping on a DVD, and your Mac needs to read it to be able to install it)
  • 9GB of free disk space (though I bet if you customize the install and leave out all those printer drivers and extra languages you can save lots of space)
Go to your apple menu, and look on the "about this mac" If your machine doesn't have the mhz's you are out of luck. If you don't have a DVD drive, you are not going to be able to install either...
K
Sep 14, 2009 | Apple iMac G4 Desktop
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Installing OSX 10.5 on G5 Mac Desktop Locks up
try to boot on 10.4, and then introduce de 10.5 DVD. Then the computer will ask to reboot, but with good options.
Jan 25, 2009 | Apple Power Mac G5 Desktop
Installing OSX 4 with external DVD writer
You're in luck if you have another mac because you can now use it's drive to install from. Connect the computers together using a firewire cable then restart the mac with the broken drive holding down the T key at the bong until a firewire symbol appears on screen. The other mac can now see it and can install the software to it as an external drive.
Otherwise you would need a firewire cd drive or USB to Firewire adaptor for your cd drive. If you get one of those you hold the alt key while rebooting and this will display a list of bootable devices.
On the latest OSX disks it has a folder for network cd/dvd access for intallation but again you need another mac to mac use of it.
All the Best
Sean
PiDIgital
Dec 12, 2008 | Apple iMac G4 Desktop
My imac g4 isn't reading the dvd/cd drive at all
it won't read it because the new os disk is double layered and the g4 drive you have probably won't read double layered dvds.  best solution is to buy or borrow an usb external dvd drive.  i did this last week and it worked fine.
Nov 01, 2008 | Apple iMac G4 Desktop
G4 350 mhz agp powermac
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Oct 15, 2008 | Apple Power Mac G5 Desktop
Imac g4 cd drive
It;'s not a great Idea flipping the mac over they have a special stand to put them on when working on them. But it should be able to cope with it. Your mac is relatively old now. With all the moving around it could have just given up the ghost.
They are quite tricky to work on with the hard drive sitting on top and the cables running over and down the side there is a stack of heat generated there. Just make sure you put ll the thermal back in. If it's not a miss seated connection it could be a number of things. Cable, heads. Trouble shooting is quite tricky. As it is a desktop, in a lot of cases it is cheaper to buy an external DVD reader/writer. They are faster now!
You should be able to install OK when it is in terminal mode. You could run disk utility but more than likely you'll have to run the installation again.
Sorry, not much help.
Sep 11, 2008 | Apple iMac G4 Desktop
Won't recognize CD Rs
hmm..odd..to say the least..you using another kind of CDR? and did you update your dvd drivers lately?
Mar 09, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Apple iMac G4 Desktop Logo
1,801 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
