Eurovox 5000 pvr
Hi,i cant get it to record,it keeps saying hard drive full or not installed,its in and running i can hear it start up,plz can u help
  • 23 Answers
Hi, them boxes are very badly designed...
You need to put something on timer then record it,
When it says "Hard drive full or not installed" it means Hard Drive empty...
I think thats the case, phone up the person who you got it off, they will tell you exactly whats wrong with it..
Anyway it needs new software, heres some info about code problem.
go to http://thechatterbox.cc and download the Chatterbox toolbar. Then Downloada program called KeyMaster on there.
For EUROVOX
Press MENU then press the Yellow button
For STARVIEW
Pres MENU then press 1570, go to Nagravision, Either enter provider number (look below) or Select your operator.
Now go to 00, Input Code into "DATA", press OK, Now go back up to 00 and press Right button, to change it to 01, Enter the 01 code in.
Provider ID is as follows,
Before Virgin Media took over, type in what ever code is next to your old supplier..
NTL - 5401
TELEWEST - 5a01
C&W - 5c01
When you find your codes of the Keymaster, you should have Key 00 and 01,
On your screen go to 00 and type the code you got of the internet,
Now do the same for 01,
The codes will change every day until new software is released.
Use the key on the bottom of your screen to type in the Letters.
Keys as of 29/11/2008 (Might have changed by the time you read this)
NTL - 00: CD 11 58 05 EE 96 E7 F3 // 01: EA B7 BF B2 D5 AA 46 AB
C&W - 00: 00 58 8D CF 27 98 04 ED // 01: 2A E0 72 B0 9E 07 9B 5D
TW - 00: 98 B0 BA 52 D3 21 08 B4 // 01: D2 EA 29 B7 B5 52 E9 AD
Posted on Nov 29, 2008
Euro vox 5000 pvr. problem is when i go to record a program on timer the box tells me its recording and when i go to watch it theres nothing there. but when i pause a program i can just unpause it and its ok so the hard drive is pushed in correctly any one have any clues why it wont let me record or is it broken
Posted on Oct 08, 2009
First ,unplug power and any other cables,open up box,( warranty will be void by this action), make sure of good connection. look at cicuit board that hard drive connects to make sure it has a good ,tight connection,( On my box c/board was not fully in place,applied slight pressure and hey presto, when all assembled and powered up,working again )
Hope this helps
Posted on Jul 26, 2009
  • 3 Answers
Hi there you need to record onto the hdd before before the box knows its ther once recorded on the box will pick it up just press record on the remote control
Posted on Jun 18, 2009
Bell pvr 5900 won't work
I think you have the wrong category, unless it's a PC-Laptop?
Apr 07, 2013 | Computers & Internet
Sagem PVR disk full error
Most likely a hard drive failure. Something called spinal failure can cause an issue that sounds like this.
Aug 30, 2012 | Sagem Televison & Video
The box wont record saying the HDD memory is full however it only shows 26% and wont let me open the file or delete the file. further it has lost everything previously recorded
Hi, this is a common problem, you need to get in touch with the place you have bought it from and tell them your hard drive is corrupt and will need formatting and re-installing the firmware, now depending on how long you have had it they may tell you you need to pay to have it fixed, if they tell you that then you would be better off getting a new one.
the chances are something has over heated and caused the data on the hard drive to be corrupt so even though it only showing 26% it means the rest of the hard drive has corrupt data and cant be recorder on so you only have 26% of your hard drive left that you can use.
over time this will happen to all dtv recorders its nothing you can do either contact the place that sold it to you or have a look in the book that came with it and contact their customer support and explain whats happening, they will then tell you how to access the service mode and this will allow you to format the hard drive and may solve the problem.
we dont have the service menu details here as its only sagem who hold them and they keep it to themselves as its what their engineers use to reset the system and solve any problems.
it may or may not work but you have got nothing to lose so either take it back to where you bought it from and ask them about an exchange or refund or look in the handbook and call sagem customer service team and ask them how to format the harddrive
also check in the settings that this is turned on: OAD Auto Updates enabled.
make sure it is enabled.
also try doing the following to reset the box it may work but most of the time if the hd drive is corrupt it will need replacing before you can record again
1. Turn off the unit for 5 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the aerial.
3. You will get an Er-09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote.
5. The box reboots in standby mode.
after this it should say OAD complete this means the firmware has been updated if it dont do anything then the chances are you have all the latest updates and you hard drive is no good.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
I have a Daewoo Twin Tuner hard disc PVR with a firmware
I had one with the same firmware faults - in the end I had to return it as Daewoo had no plans to update the firmware. When I returned it it joined a huge pile of them in Currys.
Jul 24, 2009 | Daewoo Televison & Video
Lost a lot of sky channels
sorry to say that all the eurovoxs are loosing chnls there does not seem to be a fix yet for them you will have to change box or hold on for another while sorry guys
Apr 09, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Installing a hard drive on the eurovox ex5000 pvr stops it workin
if the hard drive is new and not formatted , there will be no operating system for the computer to go past the bios start up
what you will have to do is to get into the bios , select boot preference and select cd as first preference
load an operating system( example win 8) and let the unit boot from the disc
after that has properly installed ,shut down the unit , restart and get the bios back up and change boot preference to hard drive
from then on it should start and boot from the program on the hard drive
Nov 13, 2017 | Televison & Video
Eurovox
NTL IRELAND (54 01) -- [Last Roll 13/06/2008 @ 7.15pm]
00 = 22 DO 9F EA FA CB 10 B3
01 =
9B 0B 4C 80 4F 6A 39 6B (new)
Please Google for The Chatterbox website (TCB.cc) you can get a free toolbar that provides a link to the newest keys. I always help anyone where possible but am reluctant to do so with these boxes due to their illegal nature. Please try to sort it out for yourself, thanks.
Jun 13, 2008 | StarTech.com StarView SV211K 2-port KVM...
173 people viewed this question
 Grubhead
Grubhead
