Question about Nikon D40x Digital Camera
Camera frozen Camera is on but will not operate. tokk the battery out, recharged the battery, reinstalled and it still will not work.
  • 136 Answers
Try to replace the momory stick.
Or try without it.
Posted on Nov 28, 2008
How do i reset my camera. all the buttons arent working and it has frozen?
If you take the battery out and leave out for 15 seconds and then reinstall the battery, it should not be frozen!
Dec 29, 2010 | Panasonic Lumix DMCF2 Digital Camera
Camera shut down while operating &willnot resart .New batteries inserted with negative result.
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 15, 2010 | Kodak Easyshare Z812-IS Digital Zoom...
KODAK C190 DIGITAL CAMERA...iVE CHARGED THE BATTERIES FROM 6PM TO 630PM NEXT DAY. I INSERT THEM IN THE CAMERA AND THE CAMERA WILL NOT TURN ON. WHAT AM I DOING WRONG? i RETURNED THE FIRST ONE FOR THE SAME...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 22, 2009 | Kodak Easyshare C190 12MP Digital Camera...
A640 freeezes while taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon PowerShot A640 Digital Camera
Camera Frozen in "On" Position
Hi, I read somewhere that this happens with alkaline batteries, but I have had the same problem with my rechargables (...don't use alkaline batteries in this camera). Anyway, removing the batteries with the camera in the off position and replacing them with fully charged ones usually clears the freeze. I also carry a spare CRV-3 just in case the rechargables go flat and this can help overcome the problem. Just don't leave it in the camera as they are too expensive to have it flatten them overnight!
Jul 05, 2008 | Kodak EasyShare C743 Digital Camera
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Help with frozen lense
the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 29, 2007 | Samsung Digimax S700 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Nikon D40x Digital Camera Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
