I hav a frigidaire front load washer it`s only three weeks old. it does not spin the clothes out fast enough to take the water out of them.i`ve tried all the suggestions from the repair guy who had determined it was our fault it won`t go into maximum or even high speed spin before he even looked at the washer.i had no problems with it for two weeks and now my clothes come out wet enough i can still ring water out of them. any unbiased suggestions? thanks chris
  • 121 Answers
Chris there is a pump sump that may have something in it
Posted on Nov 29, 2008
Frigidaire front loading washing machine works fine in regular wash but won't spin out enough in perma press cycle.
I appreciate your post, Kathy Saalfeld!
From my understanding on permanent press your Frigidaire washer will not spin out enough water. This could be a possible issue with your control panel or sensor within the inside of your washer. You may want to review your drain tube to assure that it is not restricted or kinked. This could be a possible problem with your drain pump or timer. You may need to consult with a professional technician for a proper diagnosis and repair to be performed on your washer. Good luck. -Matt
Feb 16, 2015 | Frigidaire Washing Machines
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
IT IS NOT SPINNING THE CLOTHES CORRECTLY AND IS LEAVING THEM VERY WET
You have two situation. One the water is not being pumped out and second the tub is not spinning fast enough to extract the water from the clothes. The latter could be due to a transmission problem and the belt is either loose or worn out. Good Luck
Jan 09, 2011 | Frigidaire GLTR1670A Front Load Washer
I have a Fridgidaire front loader. It completes the regular wash cycle, but clothes are soaking wet- it's not doing the final fast spin. When I select the drain/spin option, it drains and eventually...
Either an off balance load (unlikely if it happens all the time), a bad door switch, or a bad motor control board. Easiest repair is to try replacing the door switch, failing that, i'd call someone in to test the speed board.
Apr 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer is not spinning fast. It spins just not fast enough to get the water out of the clothes.
Most washers have a speed limiter in them to prevent the unit from damaging itself "IF" it is severely out of balance. Your solution is to redistribute the load, so it will not be out of balance and/or wash smaller loads so the machine can redistribute the load itself.
Hope this helps..
Kindly,
Jim
Dec 21, 2009 | Frigidaire FTF530FS Front Load Washer
Cloths are still very heavy and wet
Sounds like a pump problem or a kinked drain hose. The machine cannot spin or spin properly until the pumps gets the water out of the tub.
Sometimes the drain hose get plugged or kinked and won't allow the water to be pumped out so make sure that is not an issue. But, I'm more inclined to believe this is a pump problem.
Dec 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
