When making manual convergence adj. useing the consumer controls ,chassie dptv305f all control options work except red horizontal up ,down will not move at all , red vertical left right works fine , any ideas , suspect acs board ,am I on the right track ? thx. alphauno
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
Enter the menu on your TV. Use the remote control and bring up the menu.
Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
Press "Enter." A crosshair pattern will appear on your screen.
Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
white crosshair.
crosshair.
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
Press action button to enter MENU.
Navigate to SETUP.
Scroll down to CONVERGE.
Press VOL > to select.
Press CH buttons to navigate up or down.
Choose CONVERGENCE ADJ or RESET TO DEFAULT.
If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left center of cabinet.
Press ACTION button to display red center correction screen.
Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION Remote Control must be in TV mode.
Press ACTION button to display red correction screen.
Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
Use the navigation buttons to align the RED cross with the white cross pattern.
Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
To exit press ACTION button repeatedly, then press CH up.
It soundsa like you have a convergence problem. Probably only one color. (The green and red may be ok but the blue is bowed or any of those combinations) This will require the repklacement of convergence IC's and then alignment. Probably best to have a experienced tech take care of this.
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
To adjust manual convergence on your projection TV, follow theses steps:
Turn your TV on.
Let it warm up for 30 minutes.
Press the Menu button on your remote. The Main menu appears.
Use your remote to select Function, and then press the joystick.
Select Convergence, and then press the joystick. The Manual Convergence screen appears.
Select Red, and then press the joystick. A series of crosshairs appears on the screen.
Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have.
Note: You must do the outside crosshairs first.
In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair.
Note: Make the single horizontal line as white as possible.
In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair.
Note: Make the single vertical line as white as possible.
Repeat for all outside crosshairs, and then for the inside crosshair.
Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
Repeat Steps 7 through 10 for Blue.
Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Change both STK convergence IC's for reliability.
They amplify/control both horiz and vertical.
re-align after replacement.Locate them on the largest heat sink in your set!
