Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool icemaker quit
I have a Whirlpool side by side. Quit making ice a few weeks ago. Seems like no water getting to ice maker. Water in door is fine. Model # ed5phexenl00
    Sergeant:
    Champion:
  • 311 Answers
I/M itself is most likely bad. Is there ice in the mold or is it dry?
Posted on Nov 28, 2008
I own a Whirlpool side-by-side mode # GD5PHAXKQ00. The ice maker quit working so called a repair person. He said we needed new circuit boards. We ordered on-line and replaced them. We are still not...
ok when u check solenoid there were two of them one is icemaker one is water. ok. now after water leaves solenoid it runs up the back of ref. make sure u dont have a bubble in that line if it does there is a vaccum and wont allow water to make it up to icemaker., if it has undo water line as it goes into back of ref. and make sure water is coming up to there. try that ok..
Feb 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit working
Could be a couple of things.
It's not getting water due to (1) a blockage in the line; or (2) water valve in the bottom is not pumping water to the icemaker.
Or the icemaker control unit is not sending the signal to the water valve when water is needed in the ice-making cycle.
Oct 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker quit making ice; water works
is there ice in the maker but will not droup out?
Jul 23, 2009 | Whirlpool GS6NBEXR Side by Side...
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker stopped making ice - water dispenser is fine.
well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Dec 30, 2008 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
226 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
