Question about GE Security Simon 3 Wireless Home Security System
Westinghouse Security System beeping
I have an old Westinghouse Security Systems that keeps alarming every 15 minutes or so. The power box is "hot" and there's an internal transformer / finned capacitor looking item that is way hot. Unplugged all is well....Any suggestions as to what is wrong?
Brian
  • ExGreenBeret May 11, 2010
    Sounds like you may have a low battery in the main control panel. Is it an "Ademco" brand?
  • 78 Answers
Hi, as you know your system is old. The company that made your system no longer exists. There is no support for your system. No parts available. It sounds like a circuit board problem. Defects in circuit boards are not normally fixed where I work. Not cost effective to pull panel and send it out to be bench tested. shipped back for reinstallation. cheaper to replace panel and keypads. There is a 50/50 chance you may have to replace sensors Too, on that panel. Hope this helps.
Posted on Sep 09, 2009
  • 80 Answers
Sounds like the main controls battery may need replacing.
mj
Posted on Sep 01, 2009
  • 24 Answers
Hot is ok in an alarm box, especially inside where you see your finned heatsink and capacitors, if it beeps it might be because you have a communication problem, a weak backup battery or else. Check if you have any codes being displayed on your LCD or LED and check in the signification in your user manual if any. If you are connected to an alarm central they should be able to tell you what is the problem by connecting remotelly to your system. If not, well I need more details.!
Thanks,
Lucucs123
Posted on Apr 02, 2009
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home · Small Business ...
Jan 03, 2016 | Home Security
My Toyota Highlander alarm keeps beeping at a few minutes to11am and 2pm without anyone touching it. I want it reset
Disconnect the battery ground for a couple of days.It will reset once you hook it back up.Otherwise,unplug the alarm from the system.
Apr 09, 2014 | 2003 Toyota Highlander
I have an old Westinghouse Security Systems that keeps alarming every 15 minutes Model XL4600SM Key pad and its driving us crazy.. don't know how to shut it off can someone pls. help us (numeros days...
Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
Dec 15, 2010 | GE Security Simon 3 Wireless Home Security...
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
Our 2001 Winnebago Ultimate Advantage Motor Home has a The MindReader Auto Security System by SCS. I need to know how to access the reset button or how to reset in order to reprogram the keyless entry key...
Easy way is to Disconnect the main vehicle battery for a few minutes. When you hok it back up the alarm will start beeping every 5 seconds or so and this means it is in the "programming" mode. You can program up to 5 buttons at this time. SO press each one on each of your remotes one time and the alarm will respond with a loud BEEP. if you only have one remote to program just keep pressing the same 2 buttons till ou reach the 5 limit. Then it will stop beeping and you are set up.
There is an additional way to do it through the programming option of the alarm but you really need a manual to walk through those steps.
Good Luck
Steve@capriceshop.com
Dec 03, 2009 | Astra Ast200 Auto Security 4-channel Alarm...
Cant reactivate my car alarm
Try unplugging the fuse or power cable from the alarm system. Basically, just cut the power to it in any way possible. Leave it like that for about 15 minutes while you go get something to drink/something to munch on, and then go back, hook the power back up, and try it again. Sometimes resetting them like that will fix issues such as this one.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Vehicle Parts & Accessories
an easy fix is to get a dsl filter for your system and reconnect it back up to the telephone line.
http://www.safemart.com/Alarm-System-Essentials/Z-Blocker-Alarm-DSL-Filter-1EZ-A431PJ31X.htm
and no ido not work for Safemart.
if this doesnot help you email me...
mj
Jul 22, 2008 | GE Security Simon 3 Wireless Home Security...
Westinghouse Security System chirping
Those of you having problems with the beeping on the Westinghouse systems when the doors/windows open. The solution on the XL4600 is #6 this should slience that!
Oct 03, 2007 | GE Security Simon 3 Wireless Home Security...
Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it soulds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house.
Sep 07, 2007 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
350 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a GE Home Security Expert? Answer questions, earn points and help others
