Question about Apple iMac G5 Desktop
Black and white.
My son was messy aroumd with my computer and now when i get to my desktop its all black and white. I've tried everything that I know how to do. I went to display and system prefernces and tried adjusting all the color settings and still nothing. Please help its very hard to see on this setting thanks Nacole
Black and white, like if you press apple-option-control-8?
Posted on Apr 24, 2007
    Scholar:
  • 59 Answers
Removing the video card is not the first step to take....check the video cable make sure no bent pins in case it was removed then make sure it is connected firmly, then open system prefrences, go to accesibility/universal access depending on the operating system, most likely it will be the latter.check the display area to make sure the grayscale option is not selected.*****try pressing command alt/option control and 8 at the top all togetther, look for the key with the apple this is command the two hold it and the two keys next to it and press 8, i am using an apple pro white keyboard if your using anything other than an apple pro black or white then the keys may be in a slightly differnet order, this is the kb shortcut for the option i mentioned earlier
Posted on Apr 23, 2007
    Scholar:
  • 168 Answers
Try to inspect the connector linking the monitor to pc. see if there are bended pins or probably broken pins. if not try to change the monitor just for testing and see if the problem still there. but if not, that means ur monitor is the problem. also try to remove the video card and reinstall it again to its slot.
Posted on Jan 15, 2007
2 Suggested Answers
  • 25 Answers
SOURCE: My Mac looks like a Negative but almost like a
Control-Option-Command-8
failing that, try booting in other user accounts try plugging the monitor in after its booted up try booting it in safe mode does it still occur?
failing all of that try resetting the PRAM/NVRAM http://support.apple.com/kb/ht1379
Posted on Jan 15, 2011
Dc7800
What is the error message? The CPUs will not overclock on there own, that requires configuration. Some components when not installed properly with cause the computer to boot to a black screen and the fan to speed up dramatically. I've seen memory sticks and display port cables cause this. Check all your hardware and make sure everything is seated properly.
Jul 07, 2013 | Computers & Internet
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
I have an optiplex 260. The desktop was at my inlaws house. i disconnected everything and brought it to my house. When i connected everything and turned on the computer, it asked for a password in a...
press CTRL + ENTER at the same time that should disable the password security and it should boot properly. If not there is a jumper on the motherboard that you can pull to clear the password as well.
Aug 22, 2011 | Dell OptiPlex GX260 PC Desktop
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
Leaking aroumd the door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
,,n
Jul 28, 2010 | GE Nautilus 24" Built-in Dishwasher
I got a sony cdx-gt310 from my son but he lost the manual to install the wires.i need to know what wires go where.thanks signed doug
yellow- 12 volt constant
red- 12 volt ignition
black- ground
blue- power antenna
blue/white- ampilfier turn on
white and white/black- front left
gray and gray/black- front right
green and green/black- rear left
purple and purple/black- rear right
black stripe will be negative for the speakers
Hope this helps
Jul 18, 2009 | Sony Car Audio & Video
Samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Nov 29, 2008 | Samsung LCD PREVIEW MONITOR f/950 AND...
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Apple iMac G5 Desktop Logo
50 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
