Question about GE Refrigerators
Left ge stainless steel fridge and freezer door open acciently
Left town for a week and accidently left GE fridge and freezer door open. came back and everything spoiled. now both fridge and freezer won't get cool. any thoughts?
  • Nicesuit
    Nicesuit May 11, 2010
    you killed it. your fridge has been trying to freeze the world and probably never switched itself off in the last week so either the fuse is blown in the plug or the compressor has packed in or even the overloaded current has broken some other electrical parts if the light or display comes on you have probably killed it.
    President:
  • GE Master
  • 2,651 Answers
Youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Posted on Nov 28, 2008
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
Bottom freezer door left slightly ajar for approx. 24 hours on a GE Profile fridge. Now, freezer and fridge are at 28 and 54 degrees respectively and will not return to normal. What are possible...
Hi do you notice any frost in the back of the freezer? If you do not this is a bad motherboard, I would recommend calling GE directly if under 5 years old they will fix at an extremely discounted price if it over 5 then the board costs about $175.00-200.00 to buy.
Sean
Mar 28, 2011 | GE Profile PDS22SBRR Stainless Steel...
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Jul 13, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
320 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
