Question about Sony HT-DDW790 System
Have a problem with my Sony HT-DDW790 Home Theatre System
When I switch on my Sony HT-DDW790 Home Theatre System it displays the word "Protect", I have even disconnected all the speakers and I still can't solve the problem. I am getting frustrated......
  • Anonymous Apr 29, 2009
    I have the same problem too. I can't figure out what the problem is. Someone else's review states that sony receiver can have a broken solder joint and needs to be resoldered.
CLARKPINK55
  • 71 Answers
SOURCE: sony home theatre system receiver displaying PROTECT.
output stage fault probably a capacitor leaky
Posted on Dec 10, 2008
tech48
  • 624 Answers
SOURCE: Protect error
This is a failure of the power supply or the amp. In either case, this unit is one that the boards are available and should be replaced. The first thing you must determain is which board is bad.
I have been repairing these since they started making them, and can tell you that it is not an easy task to figure out which board is bad. You will need a multimeter, and then know how to use it very well.
Sometimes you can get pointed in the right direction just by knowing what was happening when it went bad.
If the unit was working and you turned it off, then the next time you went to turn it on you started getting the "protect" message in the display, you most likely have a bad power supply board.
If you were listening to the system and it just shut off on you and then when you turned it back on you got the "protect" message, then it is most likely the amplifier board.
There is one more thing to check before you ever buy a board for this unit. If the fan in the back is not turning when you turn the unit on, it may only need a new fan. Lets hope that this is your problem, it is cheap and easy to fix. The other options may be better for you to take it to a service center to properly troubleshoot The boards are a little expensive, but that is what Samsung does with these units, they replace the boards. Most all other audio equipment from all other brands do not even make the boards available.
Check the fan first, if you need the part number let me know, I think I may have a manual to look it up for you. If you want to try and check the boards, I may be able to help a little more, but this is a very difficult thing to do over the internet.
I would appreciate it if you would wait until we are finsihed communicating on this problem before you rate it.
Thanks,  Dave
Posted on Jan 22, 2009
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Posted on Mar 30, 2009
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
I have a sony home theatre system ht-ddw5000. the bd channel display says unlock, how do you unlock it
did you find a fix with that problem as i have the same issue when connecting Blue ray into BD port with HD cable! is the unit not able to handle sound and video on the bd port?
Dec 17, 2012 | Sony HT-DDW740 System
Receiver goes in to "PROTECT" mode
Try disconnecting your speakers. Then see if the unit displays protect. If it does, then the finals in your Amplifier have gone bad and will need service. If the unit comes on and there is no error, you most likely have a bad speaker.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | Sony HT-DDW790 System
Hello, I have a problem with dvd home theatre system... there is a display saying... push protector power...and i dont know how to fix it...
remove all speakers and turn it on if it still displays protect (and it probably will) the damage is done. could need a diode or an output ic. not a diy job.
Nov 08, 2009 | Sony HT-6900DP 6.1 Channel DVD Home...
Volume issues
The connections are inappropriate.re check the cable connections.
Jul 05, 2009 | Sony HT-DDW790 System
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Rear check message on HT-TXQ120 samsung home theatre
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Sony HT-DDW790 System Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
