T 580. camera does not wrok
Try downloading and installing the drivers. Get online
and got to www.google.com In the google search box type: "Fujitsu
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Webcam drivers.
You have to open the webcam software to activate or start
the webcam. There is no button to push or switch to turn on. The
webcam software is somewhere in the program list. Click Start/Programs then
search for any reference to webcam or camera. Sometimes the webcam might
be inside one of the manufacturers folders in the program list so search the
folders for it. Some manufacturers have something like Entertainment
Experience that will open and show all the entertainment devices such as the
dvd drive, webcam, media player, etc. if you see it click it to launch it
then click on the webcam or camera icon. You
can always download Manycam and install it. Go to www.google.com and in
the search box type: "download.cnet.com" (without the quotes).
Click on the link to go to the site. When the site opens look down on the
left and you will see a gray area that says Find Software. Type
"Manycam" (without the quotes) in the white search area then hit the
search mirror. When it brings back your results look for the one that
says ManyCam Virtual Webcam. Down load it and install it. Make sure
you remove the check box on any junky programs it would like to install. You
only want to install ManyCam, no additions whatsoever during the install.
ManyCam is totally FREE and easy to use, and you will always know where your
webcam software is.
Try using ManyCam
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
