Water is left in the bottom after cycle is done Maytag dishwasher
Hello buzzy220,
If you have water remaining in the bottom of your dishwasher then I would check the following:
Those are the main reasons areas of concern to investigate.. BTW, your drain line exitting the dishwasher should be routed up high and down into your sink drain system or thru the garbage disposal tap so that you have an air gap as 20YRSEXP was inquiring about..
You can run a simple test to verify all this..
Detach your drain hose from the house drain system ( from the garbage disposer or sink drain.. then route that into a rubber barrel ( be sure to keep part of the house up around the height of the countertop when you do this.. )... You should see a fairly robust flow of drain water into it when the system functions properly.. I would encourage you to run this test with no dishes inside it,.. This test will tell you if the restriction is in the dishwasher or house drain side..
Hope this helps you..
Regards,
Rick
I get a whistling sound when the motor kicks in during the wash or rinse cycle. How can I get rid of that noise?
Does drain hose touch or come very close to bottom of countertop? This prevents back-flow.
