Question about Optoma RD50 Television
How to fix black shadows appearing on both sides of the screen?
I have an Optoma RD-50, rear projection DLP set. I recently started seeing black shadows creeping onto the image from both sides of the screen. The shadow on the left side is narrower than the one on the right... also, the left-side shadow is angled at about 5 degrees whereas the one on the right is straight up-and-down. Is this a "mechanical" problem like a mirror or projector being out of alignment, or is it a more serious "electrical" problem with one of the components? If the former (hopefully), is there some adjustment I can do myself to avoid the $400 charge for a service call I was quoted by the Optoma tech I spoke to? Thanks for any advice you can provide.
This is a common experience to many Optoma owner's who thought they were buying quality eauipment - RD50/a and RD65/h. It has to do with mirrors within the light tunnel coming loose. They used inferior glue at production. I tried to repair them myself and failed and ended up installing an entire light tunnel ($$$) myself, but most should just buy another TV and sue Optoma for putting out an inferior product.
Posted on Jun 16, 2008
    Scholar:
  • 168 Answers
I beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Posted on Jan 14, 2007
Tv doesnt turn on
Problem with the Optoma DLP 50 in. Rear Projection HDTV-Ready. Television screen remains dark but I get sound.
Apr 02, 2011 | Optoma RD50 50" Rear Projection HDTV-Ready...
6 inch Shadow on tv screen of a Optomatv model RD65
OK , the tech was yanking your leg . second its the light tunnel has collasped , if parts are available maybe , other wise L/E ( light engine).
Jul 08, 2010 | Optoma RD65 65" Rear Projection HDTV
The screen appears to be dirty on inside like small greyish shadowing
the problem will be in the optical engine this needs to be replaced
Jan 24, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Optoma TV light Engine or Optical Engine Replacement
Technical Service Corp 888-942-2929 is where you can purchase an optical engine, I inquired for my RD 65. The part cost over $900, not quite worth it.
Hope this helps
Apr 15, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD50 Television Logo
653 people viewed this question
Top Optoma Televison & Video Experts
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
