Question about Dell Latitude D600 Notebook
Processor speed thanks but tere is still a problem i tried to on the speedstep but when after saving the settings i will again check bois it still showing 600mhz processor and its not working.can you tell me the solution of this kindly.
  • Cosma Papouis
    Cosma Papouis May 11, 2010
    What is the problem?
    Sergeant:
  • 306 Answers
There is a SpeedStep hot key that you can toggle and a speed step utility if you have not installed it. Dell support has the utility and instructions as well as a manual to explain when the default is active. http://support.dell.com/support/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn
Posted on Jan 19, 2009
The clock speed on Windows 7 Ultimate shows only 1.60Ghz
It depends on the processor you have installed. Dual or Quad core processors are slower e.g. a dual core listed as 4GHz is actually 2GHz per core. With laptop processors, if they have Speedstep technology then the speed will vary depending on the processing power required.
Mar 03, 2011 | Computers & Internet
Intel pentium m processor 765 2.1ghz
This might be a problem in your computer's BIOS (Basic Input Output System) settings. You can refer to your manual on how to access the BIOS, but it is usually accessed by pressing F2 or the DEL (delete) key on your keyboard a few seconds after you turn it on. Once in the BIOS you want to find the option to "reset to default" settings. Select that, save the BIOS settings and try again.
If this doesn't work I suggest contacting Dell customer support directly for help.
Dec 19, 2007 | Intel Pentium M 765, 2.10GHz...
Cpu not running at stated speed Dell d600 Latitude
Power saving methods include dynamically variable clock frequency and core voltage, allowing the Pentium M to throttle clock speed in order to conserve energy, using the SpeedStep 3 technology. for the battery ....http://www.daileyint.com/hmdpc/battery.htm
Mar 11, 2010 | Dell Latitude D600 Notebook
Hi, i have dell inspiron 8600. It is working at 600 mhz but the processor speed is 1.6 ghz. The intel speed step utility is also enabled in the setup. Kindly help
The Intel SpeedStep Technology dynamically changes processor speed to help prolong battery life. If you want it to run at 1.6GHz all the time, you will have to disable it in setup.
Feb 19, 2010 | Dell Inspiron 8600 Notebook
Cubase 4
During your computer's boot sequence, watch for a notice telling you which key to strike to ENTER SETUP. This will take you to your BIOS management. Find and disable Intel SpeedStep, C1E, or EIST, or related PowerNow! settings on AMD processors. These power saving settings are designed to slow down or shut down one or more cores of multi-core processors during times when the operating system thinks that the processing power is unnecessary, but running advanced DAW software such as Cubase draws power at very near the full system capacity, and it takes a long time to reboot the temporarily suspended processor cores. During this core reboot lagtime, Cubase is often deprived of the processing power needed to route audio signals through its complex internal bussing system (Steinberg's patented VST system link), and this power loss causes it to crash. If you disable the SpeedStep settings in your BIOS, you may notice a very gentle rise in your electric bill, as your computer's processor will be running at full capacity all the time, but you can always re-enable SpeedStep when you're not planning on recording anything.
Sep 13, 2009 | Steinberg Cubase Studio 4 Full Version for...
My pentium d 925 3.0 4m/800 processor decrease its core speed
It is absolutely normal if the processors speed and multiplier fluctuates. It doesn't mean that the processor is damaged. This technology is called Intel Speedstep. When your processor is not used on 100% it reduces its speed, so the power consumption decreases. When you need more power, the processor will automatically clock itself to higher speed.
for more information check here.
http://en.wikipedia.org/wiki/SpeedStep
If you want to turn off this feature, you have to do it in your motherboards bios. You can find it in advanced ---> cpu settings ---> Intel Speedstep, you have to choose Disabled.
Thats all
Skywolf
Jan 11, 2009 | ATI RADEON X1650 Graphic Card
Can not save current bois version: P4S8X-X BOOT BLOCK
I sent my system with intel desktop mother board and IntelPentium 4 processor to a service center for repairng. it cannot take key board and dont step into bios. but the service centre damaged my board and processor now. so how can iknow the prcessor original?
Jan 07, 2009 | ASUS P4S8X-X Motherboard
I am using 1.6 m d600 proceesor.its speed gets slower to 600mhz when i run it on battery.i have checked bios but i would not find any thing please help me out
Intel Speedstep is throttling the processor to save power. You likely have to adjust the power management settings to ALWAYS ON to keep the processor from throttling down.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell Latitude D800 Processor slows down
This is the SpeedStep technology feature of your processor. It will speed back up to 1.7 GHz when it is needed. Slowing down the processor saves battery life.
Jan 01, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
Dec 13, 2007 | Dell Latitude D800 Notebook
Dell Latitude D600 Notebook Logo
113 people viewed this question
Alun Cox
