Stand by mode
Hi i have a refurbished dell 280 pc the problem is when i press the power button to start up all i get is a blank screen saying stand by mode the key board will not work so i have a problem switching the pc off.
regards tony
  • tonyjeffrey Nov 28, 2008
    i have a dell gx280 desktop computer problem when i start up i get a blank screen with a sign saying power save mode nothing works no key board or anything
    regards tony
  • 19,396 Answers
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Posted on Nov 28, 2008
  • 1,879 Answers
Blank screen - reset monitor settings first
connect the monitor to another computer
you can't access bios if you can't see anything.
if the monitor works fine, open computer case, locate bios battery and remove it, re-seat battery after 3-5 seconds.
  • 162 Answers
>test the monitor on another computer
>on boot, does the BIOS shows up ?
  • 6,487 Answers
If you have the user manaul for your motherboard look for the steps in resetting your computers BIOS because sometimes its a setting on your BIOS that is causing the problem....
    Sergeant:
  • 306 Answers
These are things you have to research and investigate:-
1>Wake-on-LAN (most likely reason)
Those light on network and motherboard indicate "wake-on-lan" and other features are active on your computer. In this mode, when the computer is powered off, the network card is still active waiting to receive a special wake-up packet. When it receive that packet, it power on your computer and boot it up. This is used by computer support people in corporate environment for maintenance of computers during non-working hours without going to each computers to power them on.
http://en.wikipedia.org/wiki/Wake-on-LAN
To disable, you can check is in DELL Bios setup, there will be option of disabling "Wake-on LAN" feature for that computer.
2> standby mode
When you press computer power button, the computer may goes to standby mode - ( there are other mode like suspended mode and power off mode ,but in both these case the light should completely turn off).
Hope it helps :)
  • AbdulRahiman S Nov 28, 2008
    else go into power options in control panel, have a look in there, there are some options about sleep mode and hibernation, oh and go into the BIOS theres some settings (usually) along the same lines...
    rather i would suggest going to the Dell website and making sure you have the most up to date drivers, including chipset drivers.
    If that doesn't fix the situation you can disable standby by going to the control panel> Power Options, select each theme and disable standby, also goto the advanced tab and make sure your power button doesn't cause your computer to go into standby. Note that disabling standby doesn't actually fix the issue, it just disables standby.
    Genius:
  • 1,550 Answers
Unplug your power supply from the wall.
Take a screwdriver and undo the 4 screws on the back of your computer that are holding your power supply in place.
Just take a look around the motherboard to see if there are any cables from your power supply that are loose.
    Master:
  • 505 Answers
Make sure the keyboard and the monitor is connected properly. Unplug the cables and then plugged it back properly.
Disconnect the main power source and then press the power button for five seconds. This is called flea power.
Now put the power back in and then turn on the computer.
Thanks
    Genius:
  • 3,422 Answers
HI,
Please click on below link and follow the steps to disable the stand by mode.
http://pcworld.about.com/magazine/2307p168id120796.htm
What's your problem?I was working on the computer when it wnt blank, no screen, no power.
I think unfortunately you press the stand by mode key ,watch the half round moon logo switch. Please press FN+F4(lenovo or IBM)Actually it depends model to model.
I don't know ,your model of the laptop.If the problem ios same remove ac power cable / battery .After 40 secends press the on off switch .
Now insert battery and press power button.
Contract for any further instruction.
Hope this helps.
Oct 29, 2011 | IBM ThinkPad T40 2373 Notebook
Hi my dell INSPIRON/640m starts with Dell.com
try hitting the F8 button as it starts to boot you should get a screen with several options see if it will go into SAFE MODE or Last Known good Settings that worked try safe mode first,,,,,Good Luck
Jun 15, 2010 | Dell Inspiron 640m Notebook
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
I have a Dell XPS M1530 and when I turn it on, I see the Dell logo come up and it says resuming windows and then the screen just goes blank. when I press the Home button, the media center comes up...
Try starting the computer in safe mode
Press F5 every few seconds when you startup the computer.
That should take you into windows. Once you're in, just restart the computer and you should be able to get back in.
Let me know what happens.
Mar 03, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell Dimension 5150 Stuck In Pwer Safe Mode
Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
Feb 01, 2009 | Dell Dimension 2400 PC Desktop
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Nov 28, 2008 | Dell OptiPlex GX280 PC Desktop
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Dell pc not working
Try to clear first cmos settings and if it wont work soo u have a problem with VGA OR MOTHERBORARD
Nov 04, 2007 | Compaq Presario Notebook
Computers & Internet Logo
556 people viewed this question
David Payne
David Payne
