Question about HP iPAQ h6325 Pocket PC
Phone service will gone after 10-15 mins if the pda did not in use.
  • 84 Answers
SOURCE: my hp rx1950 won't turn on after a while
There could be a piece of software running that is locking up the device. You might want to check for updates to your PDA and any software you have installed on it. If that doesn't work try doing a hard reset, which will erase everything, then reinstall one application per day to see if the problem pops up after one of the applications is installed. If that doesn't work, it could be hardware issue, if there is an extra storage device in it pull it out and see what it does. You will have to troubleshoot. Try different things and see what the result is, eventually you'll be able to narrow it down.
Posted on Jun 25, 2007
0 characters
1 Points
How to unlock my motorola es400.the screen is faulty and i need to access my phone help me
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website which is doing good service and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked. Hope this helps.
Oct 23, 2011 | Motorola Es400 PDA
You may need to contact your mobile phone service provider to sign up for video service if you have a problem receiving or CNN video on your phone. does not say anything about specific phone requirements as long as
your phone is Web-enabled and your service plan includes wireless Web access you're good to go.
Sep 30, 2008 | HTC TyTN Smartphone
My Revo plus has gone completely off. Soft and hard reset did not do anything. On external power green light is on, but not the red one
On battery or on external power and doing soft & hard reset ain't giving any improvements, better check your warranty.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 01, 2008 | PDAs
Touch screen gone haphazard..... not working!!! plz help me unlock my phone... the simple phone lock can't b opened....
touch screen Solution Go to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Sep 22, 2011 | LG KS20 Smartphone
I have signal problem plz give me salotion
hi thanks for using fixya!
Kindly check your network availability, and search manually or automatically from your pda. But it is better to contact your Network Service Provider on this matter.
Apr 18, 2009 | i-mate JAM Pocket PC
Palm Centro - No signal
The phone had to be replaced!
Aug 24, 2008 | Palm Treo 500 Centro
Disney mickey mouse LT2 pda mobile phone
who manufactures this phone?
is there a user manual anywhere?
Mar 22, 2008 | RIM BlackBerry Pearl 8100
Stops while talking
Hi folks with aging JAMS. My JAM is still dying (complete shutoff) using phone. I wish it would just lose the phone signal but my unit shuts off completely during phone calls. I can have 80% charge. I spoke with a friend that mentioned on his cell phone (different manufacturer) that although his battery will show a full charge or less, the time it takes for the charge to go down is ridiculously fast once the battery is old. He watches his phone lose a charge in under an hour though it charges to full.
I wish IMATE would make some formal post regarding when to get a new battery and what symptoms are possible. I'm a bit hesitant to invest in batterys if the issue is hardware. I use the unit alot--as a PDA, a phone, etc. It gets jostled about so maybe something is lose inside, though I doubt it.
I purchased a cheap phone charger so in the car I'm recharging and at work I just keep a cheap USB to plug charger. I reserve the phone when I'm out. This is not really optimal for cell phone use but it's a behavioral fix. I figure I should be looking at a new device (despite high prices) soon.
I did a full discharge/charge cycle or two or three but only noted short term benefit. At some point the quirky behavior returned and off went the PDA cell with the 80% charge. I see dots of us around the net. Again my Jam is probably 3 years old this March.
Oct 28, 2007 | i-mate JAM Pocket PC
Phone not connected to mobile service.
Is it on the phone mode? There are 2 'modes' for this- just a PDA organiser (with no network and unable to use it as a phone), or phone mode (like the usual cell/mobile phone). Gently hold down the 'hangup/off' button. The screen will turn off momentarily. The Today screen will say Phone Off. You will not have any network on this. If you hold down the hangup/off button again, the phone will switch off and on again, and you will be able to see your network or "phone on" on the screen. Hope this helps
Sep 04, 2007 | Palm Treo 750 Smartphone
Can't use my pocket pc as a mobile phone
Hello Ric777, I would suspect the mainboard of your pda at first. But for the begining you should try to clean the contacts of your sim slot and check to see if all of them connect properly to the sim card. If all of them do connect properly, my second gues would be that the pda doesn't power on the sim card. Like memory cards sim's need to be powered first in order to work. Most pda that have this problem fail to initialise a sim because they can't suply the 3.3 or 2.7 volts needed due to a hardware mailfunction. However this test should be runned by a service center, they will have to dissasemble your pda in order to check these. In your case, you can make a hard reset and check the sim card pins in the pda. If this doesn't help, you will need service assistance. I'm sorry for not being able to help further. Good luck.
Apr 23, 2007 | i-mate Pocket PC
HP iPAQ h6325 Pocket PC Logo
123 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
