Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
Wva-430ta fix analog time
  • Anonymous Apr 09, 2009
    Analog time is an hour ahead of the digital time. Atomic signal only adjusts digital, not analog time.
    Problem Solver:
  • 5 Answers
Http://www.generalmanual.com/Watches-Clocks/Casio-WV57HA-1AV-Waveceptor-Watches.htm
find the manual here
Posted on May 07, 2009
I just received my watch. There was no manual. I thought the time was set by radio in the middle of the night. It is not set at all. It does not work. Does it need a battery? What do I do? ...
These watches do set themselves during the night. The watch come with a battery fitted so this should not be your problem.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jan 05, 2011 | Casio Gents # Mtr 303 1AV Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
How do i set the analog time manualy this a casio wave cepter watch model wva 106ha
If you haven't got instructions on how to do this, you can get
watches;
Accept terms
Apr 28, 2010 | Watches
Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Feb 05, 2010 | Casio Watches
Put new battery in wave cepor now can't get it in proper time zone. # on back, boxed [2735] WVA-105H
It may well be that the digital time displayed on the LCD is correct, but the hands (referred to as analog time in the manual) do not match.
If this is the case, to set the so called analog time:
Press the lower left button six times to enter HS (hand setting) mode.
Then press and hold the upper left button until the display starts to flash.
You can now use the two buttons on the right to move the hands forward or backwards to exactly the same ime as the digital LCD display.
When finished adjusting the hands press the upper left button one last time to exit.
Jan 07, 2010 | Casio WVA105HDA Wave Ceptor watch
Waveceptor watch WVA 105H. Reception indicator had disappeared from the display this morning, so I attempted a manual receive. After about 5 minutes the flashing display was replaced with...
I have a wave ceptor casio watch 2734 model WVA 105H, however I've lost the manaul. I have a problem, the digital time reads correctly but analogue time is incorrect. How do I move the hands to the correct time? If you could find a solution it would be most appreciated.
Aug 15, 2008 | Casio Watches
Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Apr 14, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 | Watches
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
289 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
