Question about Koss KD365 DVD Player
Unit turns itself on in standby mode
The unit turns itself on in standby mode and starts playing a dvd by itself. Is there any way to stop this from happening?
This can be a very irritating problem. Happened to me too. The only thing to do is after you turn off the unit with the remote, go to the unit and physically turn off the power to the unit with the manual Power on/off switch on the left side of the unit. Nothing else works.
Posted on Dec 29, 2007
I still have the same problem ct mode will not go away on my sc-pt750
You're under the impression that we see an historical thread that connects this request with a previous one. We don't. Start over. Tell us what is wrong and what you've done already.
This previous Fixya post addresses something similar.
http://www.fixya.com/support/t1342919-sc_pt750_screen_says_ct_mode_wont_change
Or is it "CD" mode??
There's a discussion of "CD Mode" on page 16 of the manual.
"If all loaded discs are DVDs, CD Mode does not work.
HighMAT menus and Video CD playback control are disabled.
You cannot turn CD Mode on or off during program or random mode.
If you want to play a DVD, press [CD MODE] again while stopped to cancel CD Mode. (CD Mode is also canceled when you switch the unit to standby, select another source, or change the disc in the play position.)
DVD and JPEG are skipped without being played."
STCT
MODE
Sep 06, 2011 | Panasonic Home Theater System System
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
__________________________
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
on Apr 07, 2010 | Televison & Video
I am seeing the code H02 on the display panel when attempting to play a DVD. I have attempted to play several different DVD's. I have also switched the unit to standby mode then back on. I then...
This is what the manual says:
Trouble may have occurred. The number following "H" depends on the status of the unit.
Reset procedure:
Press [POWER ?/I] to switch the unit to the standby mode and then back to ON. Alternatively, press
[POWER ?/I] to switch the unit to the standby mode, disconnect the AC power supply cord, and then
reconnect it.
If the service numbers fail to clear, note the service number and contact a qualified service person.
I know these things you have tried so here is the contact information for customer service:
In the U.S.A., contact the Panasonic Customer Call Center at
1-800-211-7262, or e-mail consumerproducts@panasonic.com, or the
website (http://www.panasonic.com).
Mar 01, 2011 | Panasonic DVD-S35 DVD Player
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
Apr 08, 2010 | Pioneer DV-333 DVD Player
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
When you play a recorded show from a DVD player
As long as you leave the unit in standby mode and do not change the disc in the meantime, it should start from the last position.
If, however, you're smart enough to have bought DVD-RAM discs (they're ACE!), you can just hit Create Chapter on the remote control and skip directly to that chapter when you next view that disc.
Mar 13, 2009 | Panasonic DMRES15 DVD Recorder
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
System unresponsive when modes are switched
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Apr 12, 2006 | JVC TH-A30 System
Koss KD365 DVD Player Logo
334 people viewed this question
Top Koss Televison & Video Experts
Marvin
Marvin
Ian Summerfield
Ian Summerfield
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
