Question about D-Link AirPlus DI-524 Wireless Router
Router need help please
Iam tring to set up a d-link air plus g dl-524 wireless broadband router getting a message up saying contact isp support can someone help please
  • margaret baker Jan 17, 2007
    do i need two modems to set it up
    President:
  • 2,961 Answers
Expand a little please, have you used the wizard, and we assume you have a seperate modem.
Posted on Jan 15, 2007
  • andrew pester
    andrew pester Jan 27, 2007
    no only one, but how far have you got with the setup proceedure.
How to install dl 524 wireless router
Hi There,
Please follow the below link to Install and setup the DL 524 wireless router.
Link :
http://www.shoalhaven.net.au/sis/setup/dlink.pdf
Enjoy !!!!
Oct 23, 2010 | D-Link Computers & Internet
I have DL-524 router- how do i put a sequrity password to my router so only my household can use it?? it doesnt say its airl plus 802.11g/2.4ghz
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 02, 2010 | D-Link AirPlus DI-524 Wireless Router
DL 524 router with a mac
When you connect the MAC to the router with the CAT 5 cable it works , that means the wired connection of the router is working but the wireless is not working.
You will need to check the wireless settings of the router.
Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router and open the set up page of the router.
Dec 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not get it to work at all. running a macbook. I have no tech knowledge. But apple talked me through it and said its not the mac. The status light keeps flashing is that normal? the power and WAN...
mine is flashing too - that shouldn't be the problem
you should specify problem a little bit more
I don't know how is your di-524 connected to the broadband, if you are trying to connect wirelessly or using cable, have you checked router config, do you need login and pass from your isp, do you use additional mode/router etc.?
Say something more about errors you are getting.
Jul 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I just purchased a D-Link 2.4GHz Wireless Broadband Router
U need to confirm that your router is connected to cable/DSL modem that has access to internet from ISP.
This is due to DI524 just a wireless router, u need to add in a modem for internet access.
Mar 29, 2009 | D-Link AirPlus DI-524 Wireless Router
How do i upgrade my firmware on my dlink dl-524?
Go to the following website to download the firmware update for the DL-524. This will save the firmware update to your harddrive:
http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware
1. Open the web browser
2. Type in the IP address of the DL-524 router.
3. Type admin in the user name field
4. Type the password you set on this device
5. Click on the Tools tab
6. Click the browse button and locate the firmware file you downloaded and saved to your hard drive.
7. Click the apply button to complete the firmware upgrade.
Mar 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Outgoing emails
Were you able to send emails (in Outlook) prior to the installation of the D-Link AirPlus DI-524?
If yes, this error message tells us that the remote server has rejected your email/message due to your host not being on a list of servers able to send the destination server mail. You will need to contact the remote server administrator for assistance with this issue. This error has nothing to do with D-Link, it is a problem with the remote host.
If no likewise, then your ISP has blocked port 25 (which is being used by Outlook for outgoing). You need to get in touch with your ISP and verify if this is the case or if you need to switch to port 26 or 587 or something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Apr 08, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 4 Port connection Problem.
Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
Feb 11, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
DI-524
make sure you have the wireless lan activated(software/hardware) and also configure your router's wireless setting(connecting thelaptop to the router by ethernet cable).write the wireless configuration down and configure your laptop with the same SSID and WEP key.it shud connect and you shud able to be good to goo..don'tforget to configure your DSL to therouter.post your router/modem/ISP details for further help
Feb 02, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
47 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
