Question about Yamaha HTR-5730 Receiver
Att uverse remote won't turn on yamaha reciever
I have att an uverse remote that turns on the uverse box, LCD but it will not turn on my Yamaha reciever. However, one the remote will turn the reciever off. How can I get it to turn the rcvr on and off? I tried all of the codes and doing the manual code method. Help.
  • 6 more comments
  • dietznet Dec 15, 2008
    I have the exact same situation. I went through all the Yamaha codes, and quite a few of them turn the Receiver/Tuner OFF< but they won't turn it back ON.
  • Anonymous Dec 29, 2008
    i have the same problem with my onkyo tx-sr806. it will turn off but not on. This is a pain in the ***
  • Anonymous Jan 22, 2009
    I have the same problem with my Sony HT-DDW660any solution ?
  • r Rose
    r Rose Mar 02, 2009
    this is bullcrap. someone please help.....
  • r Rose
    r Rose Mar 02, 2009
  • Anonymous Mar 14, 2009
    onkyo, same problem
  • hukhound May 19, 2009
    att uverse remote won't turn on my Yamaha RX-V640 AV Receiver. Turns it off OK.
  • John Brekka Sep 16, 2013
    You wont find a code that works becasue many of the Yamaha reicevers use a different code for on and off. If you have two buttons on your Yamaha remote, you wont find a code for ATT because the ATT remote is set up for the same IR code for on and off. DirecTV has a better set up for the remote in that they have an on and off buttton that you can program to work the reciever. Nothing for ATT short of buying a Logitec or other third party remote.
I think they use different codes for on
Posted on Aug 28, 2010
  • 30 Answers
Yamaha Receiver/Amplifier 5003, 5014, 5015, 5021, 5102, 5103, 5104, 5105, 5106, 5118, 5135you can use those codes
Posted on Sep 20, 2009
2 Suggested Answers
SOURCE: Att uverse remote won't turn on yamaha reciever
Do an automatic search for your code.
  1. Turn on the device you wish to program
  2. Point the remote control at the device
  3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
  4. Without releasing the selected mode key, press and hold the OK key simultaneously
  5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
  6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
  7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
  8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
  9. Turn you device on by selecting the appropriate mode and power.
Posted on Feb 02, 2009
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Jul 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have att an uverse remote that turns on my Yamaha receiver, but won't control the volume. Model No rx v480
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Mar 07, 2010 | Yamaha HTR-5730 Receiver
I have Att Uverse and a Samsung LCD. We have
If your using the IR remote, the actual colors of the tv are what is causing your problem. What I have found to solve this is go to your local ATT corp. store and order the RF remote this will solve your problem. The techs don't carry these on their truck.
Jan 01, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
Dec 25, 2009 | Emerson LD195EM8 19 in. LCD TV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Emerson tv and at&t uverse
Try code 1465. On my Emerson LCD TV the only thing it won't do is turn the TV on -- all other functions are controlled by the AT&T U-Verse remote however.
Jan 21, 2009 | Emerson EWF2704 TV
Jan 19, 2009 | Yamaha HTR-5940 Receiver
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
Yamaha HTR-5730 Receiver Logo
2,236 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
