Question about HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 - Battery
My HP Laptop doesn't recognize the battery as being the correct one. After two + years of use, it gives me a message at startup that says "Incorrect battery" even though it is the same battery that came with the computer. I replaced the battery with a new one, but I still get the same message.
Help!!!
  • 1 more comment
  • Anonymous Feb 15, 2009
    My zd8000 also says "incorrect battery", though mine started when my original battery went dead, and I bought an off-brand battery. Getting a "genuine" HP battery did not make the problem go away. I've now got an awkward, hot, desktop. I guess it's a little lighter than a desktop, buy not much.
  • greenup Feb 15, 2009
    My zd8000 also complains about its battery being incorrect, but mine
    started when my original battery went dead and I replaced it with an
    "off-brand". After that, using a "genuine HP battery" didn't help. I
    know some manufacturers have had problems with "off-brand" batteries
    overheating, but isn't that a classic "buyer beware" situation? In any
    case, I am still annoyed that it didn't go away when I tried "the real
    thing".
  • tcup628g Mar 23, 2009
    Warning. The system has detected an incorrect battery for this unit.
    Using the wrong battery will cause you to experience poor system performance
    and a possible system shutdown. System Halted. To avoid further issue,
    please install the correct battery immediately and restart
    Problem Solver:
I have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Posted on Oct 10, 2009
HP ZV5000 series has the same problem with the error message when putting in a new battery. So far the only solution I've come up with is starting the computer up without it being plugged into the charging source. Once the system is booted up you can plug the charger back in and the battery will charge. In my case you can charge the battery when the system is shutdown, but when starting the laptop up I have to disconnect the charger.
Posted on Nov 20, 2011
    Problem Solver:
  • 3 Answers
It seems that there is a design fault with the zd8000 (from looking on the forums) where teh battery charging circuit is concerned. We have two identical zd8000s and both batteries have failed. The solution is to simply remove the battery and runn the laptop without one. This works perfectly and from what I can tell most people are doing this.
Sadly it looks as though money spent on a new battery will be wasted as it will just go the way of the last one.
The zd8000 is not really a portable laptop anyway so you don't lose too much by discarding the battery - although I have seen reference to an HP product replacement scheme for the batteries if you have a certain medl and serial number.
In short - just take the battery out - then it works.
Posted on Mar 27, 2009
I have a pavilion zd8000 and i get a wrong battery detected when i boot up with it in. if i boot with it out then put it in it sees it but wont charge it. it is an aftermarket battery because thats all...
There are a lot of different laptops in the HP Pavilion series. All of the batteries for each individual laptop are similar but not exactly the same. However in a few cases the batteries are. I think that this is the situation that you are in. If so, then there is nothing that you can do about it...you just have the wrong battery.
Another problem may be that there is just a faulty connection. However it is unlikely because you said that there is a screen that comes up stating that you have inserted the wrong battery.
Here are some batteries that I found that should be compatible with your laptop. You can compare prices accordingly...
Amazon: http://www.amazon.com/Anker-ZX5000-ZX6000-ZX5200-ZX5400/dp/B003L0M28E/ref=sr_1_1?ie=UTF8&qid=1312419329&sr=8-1
Ebay: http://cgi.ebay.com/New-Battery-HP-Pavilion-ZD8000-ZV6000-NX9100-ZX5000-/200536680823?pt=Laptop_Batteries&hash=item2eb0eae977#ht_5573wt_1204
Buy.com: http://www.buy.com/prod/hp-pavilion-zd8000-notebook-laptop-battery-6600mah/q/sellerid/26076229/loc/111/216814364.html
Now speaking about the voltage problem...I don't know much about this subject so don't take my word for it, but I think that those two different voltages are for two different things. I do not thing that you can even buy a battery that has screwed up the voltages that badly. Even if you got the wrong battery for your laptop, the voltage should still be right. If the voltage is wrong, then I think that you would be having a lot more problems than you are now. So that being the source of your battery problems is unlikely.
Aug 04, 2011 | HP Pavilion zd8000 Notebook
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
HP laptop battery problem
Hello :
Try another battery . If it's the same problem , then there must be a problem with the charging jack or the charger or power cord .
good luck .
please rate !
Apr 03, 2010 | HP Pavilion zd8000 Notebook
Hp zd8000 laptop; new battery shows 100 percent charge, when I unplug power computer powers off and does not operate from the battery. Is there a setting that I need to set?
dear sir,
you didn't mention how long you are using this laptop, i mean that approxmite age of that laptop. problem you mentioned upper can happened for cause given below:-
1) if battery damaged.
2) if battery internal circuit out of order.
3) if battery internal one cell out of order.
open the battery case then if u have proper idea about AVO meter operation then u can check battery by measuring battery current (per cell) plz. then u can find out which battery is out of order, another think is u can check it by replacing saim battery unit.
thanks.
Dec 13, 2009 | HP Pavilion zd8000 Notebook
I need to replace the cmos battery in my pavillion zd8000? Where is it?
cmos battery is located inside the laptop on the motherboard
you will have to open the laptop case in order to change that
Sep 29, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not boot on battery
If every thing is correct ( the Battery, the AC adapter, etc ) then also the Power light is not turning on, then somewhere the power is not transmitting. The laptop must have a internal connection Breakage. Oh, I saw that you didn't mention AC Adapter. Have you checked it. Also check the the Control Board of the Laptop. Better you give it a Servicing.
Thank you Sir, Have a nice day.
Sep 25, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Zd8000 Trouble...Again (power)
a lot of the zd 8000 overheat and turn off, mine constantly does this on hot days of i i dont have enough airflow under my laptop. Also Hp just released a recall for the zd8000 batteries which i just ordered today. I was notified through my email so check yours too
Mar 20, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000 just over 2 years old
Sounds like you are getting a supply line issue which is well known on these models. Pull the battery, Boot into BIOS, (F10 at the splash screen) And see if it will run for an extended period of time. Next if it does Boot into Safe mode and do the same..(This is F8).. Post back..
Feb 15, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
1,723 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
