Question about ASUS P5ND2-SLI Deluxe Motherboard
System Shutting down without any messages on ASUS P5-ND mainboard
Alright, I used to have a ASUS P5-B main board before, everything was fine. Other than normal Vista based crashed and BSD from time to time. But it was ok.. i managed to fix it all. But then I thought of upgrading to dual Graphic cards, so I had to change the mainboard.
So I went out and bought the ASUS P5-ND, I installed it, plugged everything in, and I am sure I did it right.
But here is the problem. Every time I boot up, vista loads, and give it sometime, it just shutsdown.. no prompts, no messages, just like somebody was holding the power button for 5 secs and give in a force shutdown. I thought I plugged the switch cables wrong, I checked again, and it was just as the manual says.
So what do you think is wrong here?!
  • a_rishwan Nov 29, 2008
    hi.. As I suggested. Thanks for trying. That is good advice.
    Anyhow, I found the fault. My CPU Fan was loose, so the step-down technology worked in nano seconds to bring up a shutdown.
  • 144 Answers
Power Supply may be. Check how much power is needed by your motherboard & all peripherals. I think a 450-500W power supply should be ok.
Posted on Nov 28, 2008
EL1331G-01W motherboard diagram, need to know where to put the power switch on the motherboard
that is the model of computer you have .. look on the mother board and find what model it is .. like i use the Asus P5-ND motherboard .. what mother board is in your computer ?
May 10, 2015 | Computers & Internet
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
BIOS WON'T START OR LOAD, ANYONE CAN HELP ME? Mainboard: P5S-MX SE Having troubled my CPU, it works for 2 years but now this is what happened. It won't start. First, i detached all the hardware attached...
Remove The CMOS Battery, For 10-15 seconds to reset The Bios to it,s default settings.
Try the memory Module/Ram in a different Slot.
Re-seat the CPU.
Mike @ Compurepair.
Oct 16, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I need a all drivers
Go to www.asus.com; click on the support link, lookup your specific board model #, select the o/s you are running. A list of all bios/driver files will then come up. Select the drivers you need, download and install. Hope this helps.
Jun 01, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Sound on my komputer doesn't work
I want to downlod mainboard driver asus p5 vdz vm se
Apr 19, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Sharp LC-45D40U Won't Power On! Need Help!
If doesn't give error code most probably is something wrong with 5 and 3.3 volts lines. Check first the power supply and try to start the tv with all connectors removed. Let only the one between main pcb and power supply. Look for shorted voltages lines.
Apr 10, 2008 | Televison & Video
Blue screen
unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
ASUS P5ND2-SLI Deluxe Motherboard Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
