Question about Nikon COOLPIX S200 Digital Camera
ZOOM LENZ ERROR ON DISPLAY SCREEN
My fuji finepix J50 shows a zoom error on the display screen and does stay powered on is it worth gettin fixed?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Camera won't zoom correctly.
Lens errors (Zoom Errors on FinePix) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 12, 2011 | Fuji FinePix F20 Digital Camera
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Fuji Zoom Error Message
Here is someone selling the full service repair manual for the a500 for 5$. I coultn't find it anywhere online for donwload but I will keep looking...
Dec 19, 2007 | Fuji FinePix A500 Digital Camera
Display shows "Zoom Error".
In this link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Fuji FinePix S304 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom error
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
Nov 21, 2008 | Fuji FinePix A600 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Zoom Error
hi, im not an expert, to say the least, but in the few times I ran into this problem, the camera owners had to replace it. unfortunatly, this is not a very rare issue with fuji's digital cameras, so they are probobly aware of it. I dont know if they will fix it for free, but in my opinion it worths a shot.
Apr 01, 2006 | Fuji FinePix A345 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
